Results 1 to 8 of 8
Thread: Need some help with a few issues: tune inside
    Nov 2004
    Default Need some help with a few issues: tune inside
    I have enclosed a copy of my current tune and a few logs. I am having a few issues and looking to see if some of the more experienced memebers can help me diagnose/fix the problems. Here are my issues/symptoms:
    - Idle hunting
    - Car dies at stoplight (1st 5 minutes of drive after warmup)
    - Car goes into reduced power mode when A/C is on and the car has been idling for ~ 3 - 5 minutes
    - Car dies when going from Reverse to Park (car not fully warmed up..coolant temps ~ 150+).
    Now I have performed a few searches, but they left me a bit confused as to what would cause some of these issues. Thanks in advance or the help.
    Car Details:
    '03Z06 TTIx Twin Turbo
    Motor: all bore LSX
    Heads: AFR225's
    Transmission: A4 (conversion)
    Operating system: COS 3 (2 Bar SD)
    Nov 2006
    i don`t see a tune.
    Nov 2004
    Added
    Jun 2007
    Your tune needs alot of work ,
    Is your car DBW ? If it is then incresase the numbers in table c6101, this should stop the reduced power problem .
    read the custom os pdf setup it will help you out .
    Chris, welcome to the forum...
    Nov 2004
    Quote Originally Posted by Chris@Danzio
    The numbers in C6101 are maxed out.
    Jun 2007
    Thanks mate !
    Jun 2007
    Why is your C6301 set to 210 , should be more in the 190 range with a 2 bar ?
    Also check your DTCs when the car goes in to reduced pwr , It might tell you the area that is causing the problem ,
  1. Need Help With Turbo Tune (Tune and Log Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: November 10th, 2009, 09:09 AM
  2. 98 cam only minor idle issues (log inside) HELP
    By bad6as in forum Gen III V8 Specific
    Last Post: April 9th, 2009, 10:56 AM
  3. Car Running Rich with Lean Plugs (Tune Inside)
    Last Post: March 26th, 2008, 03:58 AM
  4. 383 w/Hot Cam tuning problems (tune/log inside)
    By Sherk in forum Gen III V8 Specific
    Last Post: January 8th, 2008, 08:08 AM
  5. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
