Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Let's see if this works...
    Jun 2005
    Default Let's see if this works...
    My idea to combat heat soak in the LS1 has been to securely and remotely suspend the IAT at some point in front of the lid in the path of the air it draws from (i.e. behind the washer fluid resiv...resi...that plastic container thingy that holds the washer fluid - sorry no spell check :lol.
    If shipping goes well, I plan to MacGyver my idea this weekend with some fishing string and this:
    https://www.casperselectronics.com/M...camaro1996upv8
    Yeah, maybe I'm a little crazy for blowing $$$ on something I could splice in an extension on for free. But, this way I don't have to hack up the wiring. My plan...
    ...will be to suspend the IAT sensor just behind/below the hood latch with some fishing string so that it is securely exposed in free air - the same free air the lid pulls from. Without an immediate source for heatsoak, I anticipate good things (i.e. more accurate IAT readings) from this simple relocation. I just hope 3 feet is enough and I'll have to find something to plug the hole in the lid.
    I will post results next week, assuming I get the order this weekend.
    Oct 2006
    I am suffering from the same IAT swings from heatsoak on my self made aluminium OTRCAI. Since my intake is directly in line with the grille on the front of my car I was thinking about doing something similar but with the added security of a small filter before the sensor to protect it from bug damage etc. Hopefully it will let me have one base tune for IAT's without having to change the A0014 table to keep up with the ever changing ambients here.
    Feb 2006
    Taking it out of the stream into turbulant air and moving it further away from the intake. Somehow I think you'll still get problems, just different ones.
    Hope it works out the other way though.
    Jun 2005
    To update, the parts came and I have relocated the IAT to just above/behind the washer fluid reservoir. IAT readings are much more accurate to the real temperature of the air entering the lid. NO MORE HEAT SOAK! I sat in a drive through line wating for my burger for just about 5 minutes and never broke 100*F (outside temp was 70*F). 3 blocks down the road, I was back down to the high 80's, and fell into the high 70's once I hopped onto the highway. Before the relocation, I was seeing another 20*F or more on my IAT readings in low airflow scenarios.
    I'm going to keep an eye on things over the next week to see whether or not this has a true effect on anything.
    Nov 2006
    the air box gets hot sitting over the radiator.
    i have been reduced to doing all my logging at sun set or later.
    i have found that heat soak generally makes IAT temp
    10* above the out side air temp. and at a light or at low speeds even higher.
    congrats on your invention.
    Oct 2003
    Is this in hopes of curing the hot restart stumble?
    I have been wondering how to beat that-
    PowrMax Performance
    100 mm PowrMAF
    Nov 2006
    if you look when you IAT is high the car will lean out screwing up logged data.
    Jun 2005
    Quote Originally Posted by Bruce Melton
    This is to combat inconsistent fueling. If you're having hot start problems, I'd try increasing your Startup Friction Airflow Correctoin table for the temps where you're noticing problems.
    Pics:
ID:	1786   Click image for larger version.
    Default I found a typo...
    Jeff, in post #4 you meant "windshield washer reservoir" rather than "coolant reservoir"...
    Jun 2005
    Good eye...
    Quick update - I went to a complete MAF tune (MAF threshold set to 400rpm). This combined with the IAT relocation has my AFR's within ~0.5 points on my WBO2. Transitions are now on the rich side instead of the lean side. Other than that, no real side effects noticed yet. Thinking about keeping it this way after a little fine tuning. More to come later...
  1. It works in VirtualBox!
    By endo in forum EFILive on Linux
    Last Post: August 27th, 2010, 12:06 AM
  2. how vin liceanse works
    By SGFastMax in forum General (Diesel)
    Last Post: February 6th, 2010, 01:37 PM
  3. Windows 7 - Just Works
    By NERDPWR in forum Lounge
    Last Post: June 12th, 2009, 05:16 AM
