I believe the SLP IAT sensor module is just a resistor in a pretty case. Same as putting a resistor in the IAT plug that makes the PCM thinks it's a constant 40deg with no variance. This wouldn't be a probable way to tune since you'll be taking in warmer air than the PCM is actually seeing.
