Results 1 to 2 of 2
Thread: Minor issue installing the June 13th update
    Default Minor issue installing the June 13th update
    The installation instructions for the June 13th update ask for these build numbers prior to installation:
    • Scan Tool: 515
    • ObdiiV7.dll: 644
    • Tuning Tool: 622
    I had installed the June 2nd update so I figured I need to uninstall first and then installed 7.4.2. When I went to check the build numbers, Scan failed to launch with a popup that said:
    The procedure entry point obdiiEcmBd@4 could not be located in the dynamic link library obdiiV7.dll
    Eventually I uninstalled, manually removed C:\Program Files\EFILive and then was able to install 7.4.2 and find the right build numbers.
    Jul 2005
    yeh i had exact same problem so i unziped a copy onto my desktop.
    now i have to open a folder then click on the efi icon
    i didnt have this problem with last weeks update so something must be wrong.
  1. BBL installer update: June 22, 2008
    Last Post: July 3rd, 2009, 04:28 PM
  2. BBL installer update: June 12, 2008
    By Chevy366 in forum FlashScan V2 BB Logging
    Last Post: June 13th, 2008, 09:37 AM
  3. June V2 update
    By jfpilla in forum E37, E38 & E67 PFI ECM's
    Last Post: August 13th, 2007, 10:09 AM
  4. Minor typo in the June 13th update
    By leres in forum E37, E38 & E67 PFI ECM's
    Last Post: June 14th, 2007, 04:27 PM
