Results 1 to 10 of 14
Thread: How to plot a VE table
    Default How to plot a VE table
    Hi all,
    Well we've been pretty busy in the scantool department in the latest update. Part of this update included adding DMA PID's for the E38. DMA PID's allow us to log data that is not normally available from the ECM using SAE or GM PID's.
    In the scantool in the PID/system selection drop down list you will see a group called 'E38 ECM'. These are specific DMA PID's just for the E38 (E67 to follow).
    A number of these PID's are aimed at taking the confusion out of the VE table make up of the E38/E67. At this stage we have not included all the VE components in the cal files that make up the VE calculation because are trying to implement a nice method of doing this, but, what we have done is added some PID's that will actually plot a real VE table in the scantool maps. (Map file is in this post to download).
    There is plenty of other interesting PID's in there to log too
    What we have found is the E38 really slows down once you get above 30 channels (I think it was 30), we are looking into this being an EFILive issue or the ECM switching to a different scan mode once a cerain number of PID's is selected. Either way, if you keep the channel count at or below 24 you will get super fast logging speeds. Be wary now that some E38 PID's take 4 channecalculationls!, so choose with care.
    Mar 2005
    I can't get the zip file to unzip. When I try it says "no files to extract". What am I doing wrong?
    Ron
    2014 Silverado 4X4 6.2L
    2010 Camaro 2SS-RS L99
    2007 Sierra Denali 6.2L
    2005 1500HD 4X4 Quadrasteer 6.0L, COS3 SD
    Quote Originally Posted by RonC
    Ron
    Sometimes Windows built in folder/zip feature does not work with zip files created by other applications. Try downloading and installing the winzip program from www.winzip.com.
    Meanwhile, if you don't want to download winzip, you can copy and paste this text into a file called:
    \My Documents\EFILive\V7\Maps\E38_VEplot.map. Then in the Scan Tool, load the map file E38_VEplot.map into one of the 10 maps on the [Maps F11] tab page.
    Make sure you have the CALC.E38_VE, SAE.RPM and SAE.MAP PIDs selected or the map will not function.
    Note: The CALC.E38_VE PID is available in the latest release available here:
    http://forum.efilive.com/showthread.php?t=5425
    Code:
    [FILE]
    Version=7.4.2
    DecSep=.
    [Map]
    Title.Caption=Volumetric Efficiency (Corrected)
    Title.Parm=CALC.E38_VE
    Title.Units=factor
    Title.UnitsSys=None
    Title.UnitsCode=factor
    Title.Options=StrikeOut,ShowDisplay
    ColCount=17
    RowCount=17
    Precision=5
    MinCellWidth=32
    MaxCellWidth=64
    MinCellHeight=18
    MaxCellHeight=18
    ConstrainCell=0
    XTitle.Caption=RPM
    XTitle.Parm=SAE.RPM
    XTitle.Units=RPM
    XTitle.UnitsSys=None
    XTitle.UnitsCode=rpm
    XTitle.Options=StrikeOut
    XLabels=,400,800,1200,1600,2000,2400,2800,3200,3600,4000,4400,4800,5200,5600,6000,6400,6800
    YTitle.Caption=MAP
    YTitle.Parm=SAE.MAP
    YTitle.Units=kPa
    YTitle.UnitsSys=Metric
    YTitle.UnitsCode=kPa
    YTitle.Options=StrikeOut
    YLabels=,15.0,20.5,26.3,31.8,37.5,43.1,48.8,54.4,60.0,65.5,71.3,76.9,82.5,88.1,93.8,99.4,105.0
    Font.Color=-16777208
    Colored=1
    Color=-16777211
    ColorNull=16777215
    ColorLo=65280
    ColorMed=65535
    ColorHi=255
    ColorCell=-16777211
    EmptyCell=0
    EmptyCellHide=0
    EmptySmooth=100
    Mar 2005
    Thanks Paul, I knew someone here would have the answer.
    Ron
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    I just installed winzip and its saying the file is an invalid archive
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    I don't know if it the forum messing it up or what, but I don't use Winzip, XP zip or cotton candy zip, I use WinRar.
    Jan 2004
    Yup all I use is WinRar as well. No problems here.
    Lifetime Member limited cv8r's Avatar
    May 2005
    Do the aussie L76 6.0l have a VE table? Or do we not have access to it yet? I can't find it.
    No VE table, just lots (and lots) of 2D tables that all together make up a normal VE number (which is what the above PID will log). We are working on something in this area, that is why we are not showing the 2D tables in this release.
    May 2005
    so how do we integrate this new E38 VE map into our tuning if we can't see a VE table
  1. Please explain table A0007 TPS VE TABLE cos5
    Last Post: March 18th, 2008, 06:26 PM
  2. avg ltft and a/f plot
    By ahall1 in forum Tutorials
    Last Post: June 6th, 2005, 09:58 AM
  3. Histogram Plot
    By Black02SS in forum General
    Last Post: May 27th, 2005, 11:43 PM
  4. Main VE Table ?, Logged data vs VE Table
    By dbaxter_ss in forum Tips and tricks
    Last Post: December 26th, 2004, 03:36 PM
