Results 1 to 10 of 14
Thread: Electrical Schematic Needed
    Oct 2005
    Default Electrical Schematic Needed
    I'm hoping someone can help me with an electrical schematic of the power center. I've got two diagnostics codes and need to check a relay but can't determine which is the correct one for AIR injection pump without a schematic. If someone can provide me with one or point me in the right direction I'd really appreciate it.
    Remind me which vehicle/year...
    I'll dig thru my stuff when I get home tonite...
    Edit: oh I see, 2001 Y-body: showthread.php?t=5495
    Sep 2003
    Is this what you are looking for?
    I'm old and Retired! I used to go fast. I don't go so fast anymore ...but, my cars still do!
    That's the one... ...shows relay 33 (it looks like 32, but it's 33), located in the underhood fuse center (see just below upper left):
Name:	Underhood Fuse Block.png
    Oct 2005
    Thanks folks. Just what i needed. Much appreciated.
    Oct 2005
    I've ruled out the relay for the AIR injection pump using the bidi controls in flashscan. I need to check the relay for the solenoid that controls the air bleed off on the pump. I know it's #42 in the power center but the schematic doesn't show it. Could either of you provide the rest of it?
    Quote Originally Posted by VetPet
    The diagram shows the AIR solenoid connected to:
    - PCM on one end,
    - relay 42 "IGN" on the other end;
    is this the relay you're referring to, or did I misread something (heppens alot... :lol...?
    Oct 2005
    Joecar, I found out which one it is in the power center. It is #42, the one in the top right hand corner next to the maxi-fuses. When I printed off a copy of your schematic it didn't print the whole thing but now that I went back and reopened it I was able to find it. Sorry for the trouble.
    Thanks,
    Oct 2005
    Joecar, do you how you remove the relay from the power center? I tried to pull it out but it wouldn't budge. Is there something else that needs to be released before it will come out?
    No worries...
    There's nothing holding it in, the socket contacts are pretty snug...
    If you have a strong grip, you can grip it and wiggle it out...
    or with channel lock pliers grip it [without crushing it] and wiggle it side-to-side while pulling up [without crushing it]...
    can help it along the way by prying [carefully] with a screwdriver under it...
    You should disconnect the battery when doing this to avoid shorting due to the screwdriver.
    When you re-install it, lube the pins with clean grease/petrolatum (keeps the water out and allows easier removal later on).
  1. Is schematic in the DSP PDF wrong?
    By Dozerboy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 25th, 2009, 11:48 AM
  2. Help needed using DVT on a t42
    By MyM8V8 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 10th, 2009, 07:12 PM
  3. DTC Help Needed
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: August 8th, 2007, 01:39 PM
  4. Electrical engineers anyone?
    By Alvin in forum Lounge
    Last Post: November 7th, 2006, 07:09 AM
  5. MAP changes needed with big cam?
    Last Post: September 9th, 2006, 10:20 AM
