So no stand alone yet?
Hmm, i should have checked here before buyin...
there will still need to be an adapterOriginally Posted by Blacky
because both of these plug ends are male.
True, both devices, FlashScan and wide band controllers are normally considered DCE* not DTE** devices so they both ship with male connectors that mate with the female connectors of a DTE device (i.e. a PC or laptop).Originally Posted by mr.prick
However, FlashScan can function as both DTE and DCE. DCE when connected to something like a dyno controller where the dyno computer is the host and FlashScan is the peripheral. And DTE when connected to a wide band controller where FlashScan is the host and the wide band controller is the peripheral.
*DCE: Data Communications Equipment (i.e. a peripheral communications device).
**DTE: Data Termial Equipment (i.e. the computer to which the peripheral is connected).
Most electronics stores sell "gender-benders" for a few dollars. Maybe EFILive will offer them as well.
Paul with connecting Flashscan to a dyno via the RS232 cable will it be implemented in flashscan V7 or V8 ?
It is scheduled for EFLive V8 using FlashScan V2Originally Posted by ntae
so connecting the lc1 and v2 with an adapter will be a strait forward deal,Originally Posted by Blacky
or will there need to be a firmware update for the lc1?
I believe Blacky said that FlashScan V2 will require a firmware update.
The LC-1 already spits out the AFR on it's SERIAL OUT port...
this is how the LogWorks software gets it from the LC-1 in real time,
so the LC-1 itself will not require a firmware update;
(Don't update the firmware on your LC-1, there's a good chance of lobotomizing the LC-1).
Exactly - what Joecar said
