Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: problem reading allison 6 speed TCM
    Junior Member Samdogmx's Avatar
    May 2007
    Default problem reading allison 6 speed TCM
    i downloaded the newest beta to try reading my allison,I've upated the firmware. It connects & appers to be reading fine, but when its done it pops up an error message that says bad file format, please send a copy to efi tech support.
    my truck is a 07 classic OS is 12606128
    am I doing anything wrong or is my truck just not supported.
    It should normally say unsupported TCM file not bad file format, either way if you can send it through to support@efilive.com we can take a look at what is going on.
    There was an unsupported LMM TCM file sent in just yesterday.
    May 2007
    nope I tried it twice it reads it but saved it as badfileformat.tun & wont let me open it, I emailed to you
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Unrelated, but is the same true for the A40 TCM as other modules where when you read the module, EFILive reads EVERYTHING that's in it's memory, and if one where to do a full flash later of that read, it would make the module exactly the way it was at the time of the read? If so, there's under 200k in the huge 2MB flash?
    Quote Originally Posted by Cougar281
    On some computers it is not possible to read the entire flash, both the LBZ ECM and TCM (in a a way) fall in to this catagory. On all the Delphi computers we are able to read the entire flash memory.
    This is one of the reasons we don't have full flashing on the LBZ ECM, though we could program the 2Mb of flash and the CPU's internal flash we can't read it all out, the ECM won't let us, we needed to use a debug port on the CPU to get all the data out (you need to rip the ECM apart to get to it).
    The Allison LBZ TCM will allow a full read, but, it places some restrictions on the speed it can be done!, we decided not to read the entire TCM because that would take about 45mins! (we timed it), instead we only read the calibrations and some other vehicle specific data from within the flash.
    Samdogmx, I believe Andrew at support is working with you on your problems?
    Jan 2006
    Quote Originally Posted by GMPX
    So does that mean that technically, we could full read/flash the A40 TCM, but it would just take a long time? If so, any chance we could be given the option to do either one? Reason I ask is I am going by my local Allison delaer, and I may want to preserve the entire contents after that visit. I'd be reading/programming on the bench so time's not a big deal for me.
    May 2007
    yes, I did everything as he instructed me to, but so far I'm still having the same issue.
    Mar 2007
    I am having the same problem with the TCM read failing. I have a 06 also with OS 12606128. I can send my BadFileFormat.tun file too, if it helps.
    Ron
    Jan 2006
    I just sent one your way too. Seems after my visit to the Alli dealer, it won't read now
    I don't think it's the dealer, it's like a syncronised failure of all Allison TCM reading............ok, it's a bug that must have crept in to the latest update. It will be fixed ASAP.
  1. 6 Speed Allison TCM's
    By Cougar281 in forum Allison 5 & 6 Speed
    Last Post: February 15th, 2011, 09:23 AM
  2. Replies: 1
    Last Post: July 1st, 2009, 06:01 PM
  3. BBL PID's for Allison 5 speed
    By turbo_bu in forum FlashScan V2 BB Logging
    Last Post: August 19th, 2008, 04:32 AM
  4. Allison 6 speed
    By lucky1 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 10th, 2007, 11:50 AM
  5. 6 speed Allison
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 21st, 2007, 11:03 AM
