The DFCO tables are a bit confusing to me. I know what DFCO is all about, but the tables are a bit confusing to me.
Can somone explain the DFCO MAP table? It has the rows 60,70,80,90,100 kPa. And then it has two editable colums that are also listed as kPa.
What the heck does the 60...100 represent. Is it the atmospheric pressure?
The DFCO Thottle Enable table is also strange. I see values like 1.5 @ 3600Rpms and it says that the throttle position muse be below this value to enable DFCO, yet I never see tp values that low. Is that a relative TP (above the IAC).
The m6 parameter values also seem to make no sense. B3312 = 321 (Vehicle speed muse be above this to alow DFCO M6 to occur). Does it just ignore this stuff or what? Is DFCO m6 something different than regular DFCO on an M6 car?
