Originally Posted by
SSpdDmon
To simplify things, you should program your LM1 to output the WBO2 voltage the same for both wires (red and white). Then, you just have to pick one.
IDK about V2, but on my V1 I had a 3-pin connector for AD1 and AD2 with the ground in the middle. The copper wire goes to the ground one of the other wires goes to AD1. Then, you log LM1_1, BEN_LM11, and EXT.AD1. Assuming the LM1 equation in your version of EFI Live is the same as the factory LM1 settings, it should all work just fine.
