Results 1 to 9 of 9
Thread: Need a favor,Someone w/EFILive
    Lifetime Member driver456's Avatar
    Default Need a favor,Someone w/EFILive
    Can someone log the A/C pressure pid and also the a/c voltage pid with the a/c ON,In a C5 or f body. One were the a/c works And let me know what you have.I'm trying track down an a/c problem.Thank You...Paul
    I didn't get a chance over the weekend, but I'll see if I can do it on my way home from work in about 20 mins...
    Thank you .............Paul
    Here's my log of AC pressure/voltage...
    I sat in the parking lot while warming up, turned on the AC for a few minutes then turned it off, repeat...
    I thought my pressure was a little low, but it was blowing quite cold, so it must be working [at least marginally]...
    Thanks Joe,You da man.Your the the only one that did this for me.I posted in 2 spots on another forum,And nothing.Ahh well life goes on Next question,What sensor is that reading?OK I think I can answer my own question,It must be the high pressure sensor.............Paul
    Yes it's the one you see on the AC line on the RHS of engine bay above strut tower (in my F-bird).
    My father showed me how to check that one,He say's its good.There's another one,The manual say's its in the evaporator tube between the evap and the condensor,So when I find it I'll check it.Now that I think about it,Thats the one there talking about I think,The high pressure sensor................Paul
    Well I finally fiixed my a/c turned out to be the high pressure sensor.Have to thank joecar and if it wasn't for EFILive having the a/c pressure pid who knows might of not found it...................Paul
    Glad it worked out...
