Besides changing the fan temps and doing the auto VE again anything else I need to change? I just ordered 1 today with a 80MM TB.
2001 SS Camaro M6
you may end up with some idle issues hunting surging ive seen them learn out or you could tune then out
2002 ws6 stock short block
GMPP cnc LS6 Heads 11.4:1 cr
.576 i .581 e 116 lobe
D1SC @ 10#
723 rwhp 654 rwtq on E-85
Idle learn temp should be dropped....check the tutorial section (has my idle sticky) for details.
Thanks man.
2001 SS Camaro M6
Sorry, I just looked and it wasn't there anymore. I don't remember editing it out. Anyway, under Idle>Learning>Parameters, the first cell (IIRC) is the temp at which it'll start 'learning' the idle requirements. If you run on a cold day, you might never get past the 178*F factory setting. I set mine at 160*F.Originally Posted by Spdfrk1990
B4501(min) is set to 176 and B4502(max) and set to 234. Think I should lower both by 20 deg to 156 and 214?
2001 SS Camaro M6
Ok thanks
2001 SS Camaro M6
