Results 1 to 10 of 10
Thread: Stock Tune
    Nov 2006
    Default Stock Tune
    Anybody have a stock 02 Camaro/TransAm tune for a manual transmission with traction control? I checked Holden Crazy but it doesn't specify whether or not the car's have traction control. Ever since my 98 to 02 PCM swap, my traction control always defaults to off. I've tried a number of things and would like to rule out this possibility. Thanks!
    Nov 2006
    Lifetime Member Doc's Avatar
    Oct 2005
    Quote Originally Posted by shallow bay
    Sorry for what might seem like a stupid question but here goes...Is this just the indicator defaulting to off, while TCS is still really enabled? I know you "know" the difference btw it being on or off. What I am getting at is, my first hunch is I really doubt this is a software issue. My gut says this is a wiring or, more specifically an Instrument cluster/ EBCM issue. The 98 Cluster was more autonomous in some respects, for instance it was in charge of when the Generator turned "on," as the 99+up the pcm took over this function. My whole angle with this is I am sitting with both helms manuals in front of me and, regarding the ABS/TCS Schematics, it might be a typo but the 98 TCS switch indicator led pins are opposite from the 99+up. Specifically, "A" and "B" are swapped. There is not a full break down for the EBCM in the manuals I have but, it could possibly be an avenue to check.
    Unfortuneatly, I did my swap prior to the whole segment swap revolution; I swapped the tank and, cluster. Even streching further, my car did not have the TCS option and I chucked the whole ABS module for a line lock kit to boot. I am interested to see where this leads you though.
    www.efialchemy.com
    www.greatamericancarwar.com
    Nov 2006
    Quote Originally Posted by mr.prick
    Thanks, I appreciate it.
    Nov 2006
    Quote Originally Posted by Doc
    Definitely not a stupid question. I didn't even think about that possibility. I confirmed today that traction control is actually off.
    I was thinking the same thing but wanted to rule out all of the possibilities. I flashed the tune above into my car and it made no difference. The traction control was still defaulting to off.
    I agree but it doesn't make any sense. The only thing I touched was the PCM. I have checked all of the fuses and most of the wiring and it all checks out.
    The ASR/TCS generator?
    Is there anyway you could post a picture? A guy from another forum sent me the wiring schematics for the ASR/TCS but I have nothing to compare it against.
    http://i60.photobucket.com/albums/h1...der/202765.gif
    http://i60.photobucket.com/albums/h1...der/202763.gif
    http://i60.photobucket.com/albums/h1...der/202761.gif
    http://i60.photobucket.com/albums/h1...der/202756.gif
    Nov 2006
    Doc, did you ever get a chance to scan those ABS/TCS wiring schematics?
    EDIT: Nevermind, I found them.
    http://forum.efilive.com/showpost.ph...4&postcount=21
    Oct 2005
    Argh,
    mailbox was full, sorry. Back on track. Ready to help when you are ready.
    www.efialchemy.com
    Mar 2004
    How do you open a php file?
    2000 Camaro SS Convertible
    M6,
    LTs, AFR 205s, Comp xer 220/224, LS6 intake, Ported TB, AR TT IIs
    Member neil's Avatar
    May 2006
    Rename it to .tun
    Regards,
    Neil
    Mar 2004
    Quote Originally Posted by neil
    Rename it to .tun
    Regards,
    Neil
    OK, got it, rename wasn't working, had to "save target as" and thanks!
    M6,
  1. Need Stock Tune
    By SRT10KLLR in forum Gen IV V8 Specific
    Last Post: October 25th, 2009, 07:40 PM
  2. LQ9 stock tune?
    By ALLslowNOshow in forum Gen III V8 Specific
    Last Post: September 21st, 2008, 08:32 AM
  3. Tune VE and MAF tables or leave VE stock and tune MAF only
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 4th, 2008, 08:05 PM
  4. Stock 04 Z06 tune
    By badsi in forum Gen III V8 Specific
    Last Post: May 12th, 2008, 10:47 AM
  5. Stock 07.5 Lmm Tow Tune
    By newguy2diesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 29th, 2007, 11:26 AM
