Results 1 to 8 of 8
Thread: throttle cracker
    Lifetime Member Boost's Avatar
    Dec 2006
    Default throttle cracker
    I always hear that it makes a big difference. What do you modify and how to improve off idle response (I imagine that's what it does). Thanks
    8.7 @ 84 (1/8 mile) bolt-ons
    Jun 2005
    "Off-throttle" control is probably a better description for it. I use it to make sure that when the throttle is 100% closed, the motor isn't 'bogged down' too much during deceleration. I like a little engine brake feeling, but not so much that it makes you lean forward when you lift off the gas. I also use it as a stall saver (400rpm row). By populating the below idle cells, it helps keep the revs from dipping too low if they start heading that way.
    Dec 2006
    Thank you. So it's not worth messing with for a performance "feel"?
    Jun 2005
    Quote Originally Posted by Boost
    Not so much. It's more of a quality or drive-ability table. The only performance thing I started to do with it is jack up the cells in the 4600rpm and above rows. It's like the 0.1hp mod. :lol: If the throttle body is jacked open 100%, I want the IAC open pretty much all of the way too (every little bit counts, right?).
    Jan 2005
    I would put it in the drivability category too. TC made a huge difference scooting thru school zones and parking lots.
    Mar 2004
    Quote Originally Posted by SSpdDmon
    My throttle cracker deactivates when the clutch is depressed, am I missing something?
    2000 Camaro SS Convertible
    M6,
    LTs, AFR 205s, Comp xer 220/224, LS6 intake, Ported TB, AR TT IIs
    Aug 2004
    Throttle cracker is exactly how it sounds. It cracks open and adds airflow. It has a MAJOR effect on how the vehicle drives. It also may cause a surging, or fix a surging/ make or take away a stuck cruise control effect..
    When you add to one table, it effects every other table. For example, if you modify desired airflow table, that makes the cracker table off, so it needs to be modified by the same percentage in the opposite direction to bring it back in line with the rest of the tables.
    Mar 2004
    Quote Originally Posted by DaddySS
    Does everyones throttle cracker de-activate when the clutch is depressed?
    M6,
  1. how to tune throttle follower and throttle cracker?
    By z28ls1818 in forum Gen III V8 Specific
    Last Post: September 19th, 2010, 03:43 PM
  2. Throttle cracker question
    By samh_08 in forum Gen III V8 Specific
    Last Post: May 6th, 2009, 04:26 PM
  3. throttle follower/cracker
    By drdarthinvader in forum Gen III V8 Specific
    Last Post: December 10th, 2008, 04:15 AM
  4. Throttle Cracker P/N
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 27th, 2007, 02:32 PM
  5. Throttle Cracker and Follower
    Last Post: June 6th, 2007, 11:11 AM
