Results 1 to 9 of 9
Thread: 98 s10 converted to carb but still has 4l60
    Default 98 s10 converted to carb but still has 4l60
    I had a guy call me about a 98 s10 that he put a carb 350 in but left the wiring harness and electronic tranny 4l60e I think. The tranny doesnt shift right because there is no input from the motor. Can I go in and make the tranny work right with the carb motor?
    99 Z28 Camaro|LS1 Heads & cam Tuned by LSX Power Tuning
    2003 CC Duramax Dually|19.5 w/245/70/19.5|Tuned by LSX Power Tuning|5in exhaust
    2009 G8 GT Vararam CAI|Tuned by LSX Power Tuning|GXP Mufflers|Custom System
    2006 CTS-V K&N CAI|OBX Headers|Cammed LS3|Tuned by LSX Power Tuning|
    No, I think you need a special standalone module from like Jet or another similar company that provides the trans with the proper inputs so it can shift right.
    Thats what I figured but there has to be a way to do it with efi live.
    Does it have the trans controller? If so, have him build a bench harness so you can hook up EFILive and see if you can do it that way.
    For the PCM to operate the trans. it requires various sensors such as TP, VSS, ECT, CKP, MAP, Brake Switch, and possibly others.
    Duh Erik, should have thought of that.
    So basically he either needs to convert back to EFI or get a standalone module b/c trying to get all those inputs would be way more of a hassle than just ponying up $150-200 for the standalone module.
    The modules from Jet or TCI would still require some of those inputs in some form.
    Well then Im out of ideas. Sorry man
    [quote=So basically he either needs to convert back to EFI or get a standalone module b/c trying to get all those inputs would be way more of a hassle than just ponying up $150-200 for the standalone module.[/quote]
    There a lot more than $200.00. Most of them still need TPS and VSS at minimum. They usually run in the $800.00 - $1200.00 range.
    Aaron L.
    Conover, NC
  1. Who's converted an '02 6.0 truck to electric fans?
    By HTMtrSprt in forum Gen III V8 Specific
    Last Post: March 9th, 2009, 01:58 AM
  2. Converted from man. to auto OS questions...
    By exploder in forum General (Petrol, Gas, Ethanol)
    Last Post: November 15th, 2008, 02:05 PM
  3. tuning carb intake and elbow
    Last Post: July 1st, 2008, 04:25 AM
  4. vz v6 4l60
    By zrx1200 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 21st, 2008, 10:09 AM
  5. Trying to use 4L60-E with 4-barrel carb
    By towline_5 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 22nd, 2007, 06:33 AM
