Results 1 to 7 of 7
Thread: Unknown bin file format.
    Dec 2006
    Default Unknown bin file format.
    I used EFI Live tune 7.4 w/E85 to read my 07 alli 6 speed. I selected the controller Allison Trans (6spd) from the drop down menu, checked status, and then hit start. It looked fine, took about 5 minutes. Then got this message:
    The file has been saved as C:documents setting….badFileFormat.tun
    Please send that file to EFILive for analysis.
    The only thing i didn't understand during the install was for the E85 was the image file stuff.
    Instructions:
    Make sure you have V7.4.2 with the build numbers shown below (or higher) installed on your system.
    • Scan Tool: 515
    • ObdiiV7.dll: 644
    • Tuning Tool: 622
    You can check the build numbers of the software currently installed on your system using the Help->About menu option.
    Exit from all EFILive software and backup the entire folder:
    \Program Files\EFILive\V7
    (copied this to my desk top)
    Download here:
    http://download.efilive.com/software...660_646_58.zip (13.1Mb)
    http://download.efilive.com/software...660_646_58.md5
    (If desired, use an MD5 checkusm program to verify the downloaded file's MD5 checksum.)
    (Downloaded the zip file)
    Unzip the contents of the downloaded file into
    \Program Files\EFILive\V7, overwriting any existing files with the same name.
    (I extracted the zip file, then copied the files to the file to the V7 folder over writing the existing files. I didn't unzip them into the v7 folder)
    Copy the contents of the unzipped Images folder to
    \My Documents\EFILive\V7\Images
    (I copied the contents of the unzipped image folder to the correct folder)
    After installing this update, the build numbers will be:
    • Scan Tool: 527
    • ObdiiV7.dll: 660
    • Tuning Tool: 646
    Make sure you update the FlashScan V2 firmware to V4.2.58. It contains updates required for E38 DMA PID logging.
    (My files are the same for Scan tool and tuning tool)
    My firmware says: 2.04.58
    However, the EFI site says to ensure you have:
    I wonder if they transposed some numbers or do I have the wrong version? My V2 firmware is dated 9 Jun 07, so I think its the most current.
    I don't need the LBZ Calibrations files anymore (dated 13 Jan 07) do I?
    I don't need the Duramax LBZ Default PIDs files anymore do I?
    Why did I need to backup the V7 folder to my desktop? I didn't do anything with it. What's its value/purpose?
    07 3500, CC, DRW, LB, 4x4, 486RWHP/909Tq LBZ, McRat EFI Live, SC IV trans (1057), Cogs, sleeves, blocked no finger, PPE race valve, KD dual lift pumps, TxC Fan Damn. 5,000 lb 2004 Arctic Fox 1150 truck camper, 06 Stingray Powerboat 230LX, 23ft, 350 CDI/300hp. Colorado Springs.
    Junior Member Samdogmx's Avatar
    May 2007
    Im having the same problem, http://forum.efilive.com/showthread.php?t=5517
    they are working on it
    Dec 2006
    Thanks, at least I'm not the only one. I'll send em the file when I get off work. Someone else reported the same problem and fixed with a re-install. I'm also going to try that tomorrow.
    It seems it was an issue with the firmware that was issued with that download, previous firmware versions do work. Paul is working on the problem.
    This has been fixed in the firmware available to download in my post.
    Please update your V2 to this verison.
    If you need calibration files for the Allison they were recently updated and posted in here -
    http://forum.efilive.com/showthread.php?t=5624
    Member Treurentner's Avatar
    Nov 2005
    Hi Ross,
    I downloaded your Firmware version_60 (thought that it would be a good idea to have the newest version), but there are some update problems with my V2 unit. The communication stops (after 4k of transmitted data) and it shows the new firmwarenumber but is still in polling mode, when I try to downgrade to the older fw I get the version verification error 304.
    I include a pdf to show the screen shots.
    What can be done to fix this?
    Many thanks for your support.
    Marco
    Sometimes the counter and progress bar will freeze during the reprogrmming, that is ok.
    However, if the two orange LEDs continue to flash even after the programming is finished (after about 30 seconds), then the firmware has not been updated successfully. In that case, retry programming firmware version 60.
    If you cannot get the firmware programming to complete, please send me a pm (to blacky).
  1. New DVD format
    By Chevy366 in forum Lounge
    Last Post: October 26th, 2009, 05:44 PM
  2. Logging format
    By Spindoctor in forum General
    Last Post: April 30th, 2008, 05:46 AM
  3. CAL file format
    By runrun in forum Tips and tricks
    Last Post: August 28th, 2007, 06:40 AM
  4. EfiLive file format question...............
    By FreddyG in forum Gen III V8 Specific
    Last Post: January 4th, 2007, 11:29 AM
  5. 97 PCM "Bad bin file format"?
    By caver in forum General (Petrol, Gas, Ethanol)
    Last Post: October 19th, 2005, 12:13 AM
