Results 1 to 10 of 11
Thread: Scanner help
    Nov 2006
    Default Scanner help
    How's it been going guys?
    I just bought a 2004 Chevy 2500 4x4 with a nicely warmed over LQ9. I wanted to do some minor tunning on it so I bought a used V1 setup that has been upgraded to V2. I got everything Licensed and rolling.
    My problem lie's with the scanner. I can get it to scan for the life of me. My dash doesnt move nothing. I have check my PID's and and run the systems test. I can even get the O2's to send anythign back to the software. I am at a loss for what to look for. Any idea's?
    Any help would be appreciated.
    Jun 2007
    Did you press the green connect button up the top?
    Also if you did that, Press the yellow button down the bottom of the screen. That will get your scanner working.
    Nov 2006
    I have the scanner connected via the green connect button. I also tried the yellow button at the bottom of the screen. still no luck. WHile connect with the engine running my guage screen does nothing....
    Oct 2006
    Quote Originally Posted by wickedred
    You have to validate the PIDs.
    Shift>F2 or under INFO at top of Scan Tool , while connected .
    2006 Trailblazer
    Lifetime Member Doc's Avatar
    Oct 2005
    Post up some screen shots of your selected PIDs, etc.
    www.efialchemy.com
    www.greatamericancarwar.com
    Nov 2006
    I will get some screen shots of the PIDs after work.
    Check the following:
    - connected (you already checked this),
    - pids selected on the PIDs tab,
    - validate pids (only need to do this on the first time),
    - press the RED button;
    I noted that the guages don't move if you press the yellow button.
    Aug 2005
    With the Yellow button pressed, what do you see there?
    Nov 2006
    I validated the PID's on lunch. I got it to log but it runs super slow. Any idea's about that?
    Aug 2005
    If it logs super slow, then you probably have too many channels of data selected. On a 99+ Gen-III controller, to achieve 10frames of data per second, you need to log 24 channels of data or less. Above that it begins to drop progressively as you increase the number of channels.
  1. Scanner keeps locking up?
    By Slow73 in forum Gen III V8 Specific
    Last Post: April 12th, 2010, 12:18 PM
  2. Questions about using the scanner
    By 2000Transam in forum General
    Last Post: February 25th, 2010, 10:46 AM
  3. AVG virus scanner
    By joecar in forum Lounge
    Last Post: July 29th, 2009, 08:59 PM
  4. scanner keeps disconnecting
    By Ls1joe in forum E37, E38 & E67 PFI ECM's
    Last Post: July 24th, 2009, 05:15 AM
