Originally Posted by
Doc
Just a few questions to get us on the same page. This is on a 01 vette and you are attempting to run OLSD in order to AutoVE correct? Do you intend to run the MAF in the future?
Some observations...In the tuning tool, under Properties I would suggest viewing your VE units in the default (g*K/kpa)- Not a deal breaker but, I would just get used to seeing the numbers as the PCM does. The same goes for any fueling tables where you have the option to view those units as the pcm does...EQR vice AFR. This transition will solve alot of possible future headaches where you could be trying to track down a pesky modifier table that is not allowing you to command what you really want. See Appendix B of the tuning manual for proper explanation. In caveman terms, AFR is nice for us nuckle dragging humans but does not add up for strict mathematical computers.
Some recomendations about your tune...{B3605} Commanded fuel when in open loop does not have the useable resolution like {B3647} found in the Custom OS's. Specifically in your {B3605}, you have the warmed up values set to "1" or 14.63 which is going to have you using STFT's. As an example, I have provided a B3647 table for reference only. In the example I have the warmed up values slightly leaner.... .9951 = 14.71 in order to avoid the STFT's. Under DTC processing Enablers you have P0101, P0102, and P0103 all set to 2 trips, set them to 1. Set all of B5001 to "0" and you will now properly defaut into full SD. Just for giggles leave the DTC Mil enablers P0101, P0102, and P0103 to "MIL" just to verify for certain that you do in fact have the failure. After you are sure you are in full SD, then reset the MIL to NO MIL so you can be altered to new MIL's that could pop up.
I understand you are just starting out. Don't be afraid to ask questions here. I would highly recommend going to a Custom OS with the setup you have.
Thanks for sharing your experiences, many others will learn from it as well.
