I Have a 05 lly 4x4
I just lifted it and put on 37" toyo's
I used the recal in Efi Live got the speeedo right but now it pops the abs light on.. What gives?
Been searching forums for the past 2 hours
I Have a 05 lly 4x4
1972 Chevy Blazer, Twin Turbo Duramax 6.6
69 Maro TT 427 LSX, Wayne due Vett frnt sub,
Lateral Dynamics 3 link rear, D 60,
T56, 18X10' 18X12 Boze Forged Speedsters,
13" wilwood 6 pot fronts 13" wilwood 4 pot rears,
(all Still under construction)
It is likely that the front tires are now out of calibration. Before the rear tires got corrected, the ratio from front to rear was OK with the ABS module. Now the different speed inputs are a problem. The ABS module "EBCM" needs a tire size calibration change. Do you have a buddy at a GM dealer?
Al
