When a pidlist is copied/pasted (blue section), the operation copies the pids ok but fails to copy custom units and alarms (green section).
I'd like an option to alter the default naming profile for the tune files. The default of increasing a file count by "1" more that the last file name is OK, but I'd like to have a date/time stamp instead of a sequence number. This would help a huge amount now that BBF is running as it would allow a better idea of the what the tune files are.
To give an example, I did a bit of dynamics testing at lunch time today and flashed in maybe 5 tunes. Then went back to work and at afternoon tea, I did a new tune to flash in and test on the trip home. I flashed it in via BBF, but realised soon after starting that it wasn't the latest tune. I had forgotten to save the tune to the SD card, but didn't realise this as I'd forgotton the file number. A date time stamp like mmddhhmm.ctd would be good, adding in a 4 digit year would be perfect ( but might cause issues with the length ).
Simon.
I would like a way to group calibration tables to a user defined section. Similar to how you can group selected tables to the favourites tab.
For instance you could name a group "exhaust" & place in this group all the tables you modify when changing an exhaust system. This way you dont need to trawl through the tree to get to the pertinant tables for something where a script is of no real use.
The Tremor at AIR
You mean like multiple favourite lists (with each list being able to be renamed)...?
Is there any plan on implementing a variable TCC enable temp function for GEN3 auto transmissions?
How about more maps in the maps tab.
The map bar can easily fit A-Z instead of A-J.
LC-1 WBO2
When BB logging (just displaying live data ie. not recording), I would like to be able to have every PID available when scrolling down through the live data without it going slow.
Have it where the V2 only commands the ECM to stream data of what PID's are currently displayed. So, as you scroll down, the next PID is commanded and displayed and the PID that dissappeared off the top of screen is no longer commanded. This would allow me to have a PID group that has more than 24 channels selected, and no restrictions on data speed. Also, maybe have a button on the V2 that can be pressed that will record current displayed data.
You could do a similar thing on dashboards in V7/8. Have several dashboards, and, as you flick between them, a new PID list automatically gets streamed from the ECM.
I hope I explained it correctly (compared to what is in my head)!
Dave.
