Page 16 of 21 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 204
Thread: options request : post your ideas
  1. #151
    Quote Originally Posted by Biggsy View Post
    When BB logging (just displaying live data ie. not recording), I would like to be able to have every PID available when scrolling down through the live data without it going slow.
    Have it where the V2 only commands the ECM to stream data of what PID's are currently displayed. So, as you scroll down, the next PID is commanded and displayed and the PID that dissappeared off the top of screen is no longer commanded. This would allow me to have a PID group that has more than 24 channels selected, and no restrictions on data speed. Also, maybe have a button on the V2 that can be pressed that will record current displayed data.
    You could do a similar thing on dashboards in V7/8. Have several dashboards, and, as you flick between them, a new PID list automatically gets streamed from the ECM.
    I hope I explained it correctly (compared to what is in my head)!
    Dave,
    +1... I like that idea.
    That is similar to what some scantools like the Genysis/Nemysis do... all pids are being logged, the ones visible on the screen are updated at high priority, the ones not visible on the screen are updated at low priority, and you can dynamically scroll/page up/down thru a long list of pids; it also allows you to move individual pids relatively up/down so that you can group pids together on the screen.
    This allows all pids to be quickly viewed when I have no idea what I'm looking for when troubleshooting.
  2. #152
    Lifetime Member Biggsy's Avatar
    Jan 2007
    it also allows you to move individual pids relatively up/down so that you can group pids together on the screen..
    I wanted that too, but couldnt think how to explain it!
    Your reason for wanting this is the same as mine, you dont always know what PID you want.
    Dave.
  3. #153
    Jul 2007
    Default V2 Black Box Config Changes.
    Unless I missed this at some stage, I'm pretty sure it's not available yet.
    I's like be able to update the V2 config files using the SD card and not plug it directly in to the computer. Having a config section that holds the same data as the V2 "config" filesystem would be great, then a new option under "setup" for "V2 Config" and have a load / save option, that copies the data between the local storage and the SD card.
    Some advantages would be...
    • Faster changes for switchable tune options.
    • Easy updates to config files ( ODBC descriptions etc ).
    • Easy changes to PID selection files.
    • Less hassle for people who have a "semi-permanent" install of the V2.
    For some time now I've been doing a fair bit of tweaking and the V2 stays in the car all the time. I BBL a number of trips, then make adjustments based on the logged data, save the tune back to the SD card and the laptop hardly sees the V2 now.
    having another directory under EFILive on the SD card for "config" shouldn't be too hard to arrange....
    Simon.
  4. #154
    Nov 2006
    A utility for creating calc_pids
    LC-1 WBO2
  5. #155
    Jul 2005
    you mean notepad?
  6. #156
    WiFi/Bluetooth connection between future FlashScan device (V3) and future OBD (OBD-III).
  7. #157
    You mean like this which is part of the V8 Scan Tool software V8.
  8. #158
    Nov 2006
    No, I meant something more like notepad.
    It seems my software is in need of an update.
    LC-1 WBO2
  9. #159
    Sorry, I should have been a bit clearer. That part of the V8 software (the scanner and tune editor) is not released yet.
    Yeah "notepad" I had a good laugh too
  10. #160
    Quote Originally Posted by redhardsupra View Post
    you mean notepad?
    lol...
    I use slickedit, it applies syntax coloring...
  1. T43 Ideas
    By oztracktuning in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: February 9th, 2009, 01:12 PM
  2. E67 2.4 LE5 With VVT any Ideas?
    By Quasimotor in forum E37, E38 & E67 PFI ECM's
    Last Post: January 31st, 2008, 10:03 AM
  3. Any ideas up front
    By trudynosports in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2005, 01:20 AM
