Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: LMM DEAD tables!!!
    May 2006
    Exclamation LMM DEAD tables!!!
    Torque based fuel b1102 in the LMM I have been playing with is throwing a curveball at me. No matter how I adust the table it does not change in the least when logging. And table B1115 also seems to not be responding. I am resorting to the age old tuning method of multiplicity and my shifting is being comprimised because of it. I need HELP.
    05 LLY CC/SB D/A, EFILived to the tune of 530rwhp.
    Jun 2007
    Default same here
    I've also been playing. Seems like I have been getting decent results with the main injection pulse and boost control. What have you been doing with with these tables?
    May 2006
    all of the other tables I have tried are working.
    Very odd indeed, they are the same tables as the LBZ uses (and I assume they work ok?).
    May 2006
    Ross,
    I can send you the tune and some logs if you need.
    No problem, I'll be back on to LBZ/LMM late next week.
    EFILive Reseller
    Nov 2005
    Works for me. I've had some decent results with the LMM so far.
    www.kennedydiesel.com
    Specializing in Duramax Performance
    More than just a salesman-I use and test the products that I sell on a daily basis.
    Superflow Lie Detector in house
    May 2006
    Well if it tunes basically the same as the LBZ then I don't know whats up. I haven't tried it since the new update. Maybe the old software was the problem.
    May 2006
    I recently bought an 08 LMM and have been having these same tuning issues. I have been tuning other LMMs with these same issues. The LBZs that I have tuned do not have these same issues.
    B1161-B1165 do not correlate properly or completely with B1167-B1177. I have entered values in all of these tables that should atleast flare a shift but they don't. I have also maxed out all of the torque limiting tables. I have also ventured into the tcm torque tables to try and fix the problem. The most commanded fuel I am getting is 103 and I am commanding 120.
    These PIDS also help when tuning the LBZs and I think they would help with the LMMs also.
    - Engine Power Limiting Factor GM.TRQ_FACT_DMA
    - Engine Torque Reference GM.ENGTRQREF_DMA
    - Main Injection Timing from TDC GM.MAIN1CA_DMA
    - Pilot #1 to Main Injection Time GM.PILOT1MT_DMA
    - Pilot #2 to Main Injection Time GM.PILOT2MT_DMA
    - Pilot #2 to Pilot #1 Time GM.PILOT2P1T_DMA
    - Pilot Injection #1 from TDC GM.PILOT1CA_DMA
    - Pilot Injection #2 from TDC GM.PILOT2CA_DMA
    - Pilot Injection #3 from TDC GM.PILOT3CA_DMA
    - Shift Torque State 1 GM.TSFTC1_DMA
    - Shift Torque State 2 GM.TSFTC2_DMA
    - Torque Limiters Active GM.TRQLIMACT_DMA
    Please help!!!
    May 2006
    Update! B1167-B1177 do nothing. I zeroed them out and maxed them out and they had no affect on the commanded rate in the logs at all. Please help Ross!!!
  1. Dead 02
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 09:29 AM
  2. [B]HELP[\B] Another Dead PCM
    By ls1vt209 in forum Gen III V8 Specific
    Last Post: March 26th, 2009, 04:13 AM
  3. E38 Pcm now dead
    By ls1vt209 in forum Gen IV V8 Specific
    Last Post: February 22nd, 2009, 04:33 PM
  4. Is my PCM dead?
    By kenkaru in forum Gen III V8 Specific
    Last Post: March 22nd, 2007, 08:08 AM
