Anyone know why when opening the Logged Data File it opens to the Logged data folder? It used to open to the log files. Is it me? It's annoying.
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
I may not understand the question correctly, but I think this is what you mean:
In the Properties window on the [Folders] tab page, you can set whether you want the EFILive software to rememeber the most recent folder used or to always default to the specified folder.
If the little yellow "folder" icon is present next to the folder name then EFILive will remember the last used folder. Double click on the folder name to toggle the yellow icon.
Note: Not all folders can be set up that way.
I tried the same thing and where as the PID or Maps folder open and show you the available pids or maps, when you go to open a log file it only goes to the 'Logged Data' folder, not the contents of the folder.
I hope I explained that clearly.
Ah, ok I see now... added to the list of fixes for the next release.
I see the same thing.Originally Posted by Ninety8C5
Thanks for the clearer explanation.Originally Posted by Ninety8C5
2003 red vert
Mods:
LPE 100mm MAF
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
