Results 1 to 10 of 11
Thread: Noob Help Me Please
    Jun 2007
    Default Noob Help Me Please
    Just got my v2 tonight, went throught the setup proceedures that came with the box. When i go to connect to pcm it says no cable detected. When i plug it up to my 98 z28 it will cut off the v2 if it's connected to the laptap. When i plug it up without the laptop it just flashed 4 of the 5 lights. Is this a bad cable or am i doing something wrong?
    Thanks,
    Dennis
    Lifetime Member Doc's Avatar
    Oct 2005
    Have you tried plugging in the V2 to the usb port on the laptop first and then plug into the data port? And you are key "on?"
    www.efialchemy.com
    www.greatamericancarwar.com
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    1. Turn the vehicle's ignition to the run position
    2. Plug FlashScan V2 into the OBDII port
    3. Check for proper bus recoginition in lower right hand corner of V2 screen (VPW or CAN). VPW is what you need for the Z. If you see N/A, start over or try CTRL left/right arrow.
    4. Plug FlashScan V2 USB cable into PC
    5. Wait 10 seconds or so
    6. Launch scanning or tuning software
    7. Connect away!
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Jun 2007
    yurn the key on
    plug in the v2
    no screen
    orange, blue, orange, green light stays lit
    nothin else happens. if i plug it in to my 02 tahoe no light light or anuthing cut on like it doesn;t even get power.
    Jun 2007
    no matter how i do it if the v2 is plugged in to the laptop and pcm it instantly looses power. As long as the pcm cable is unplugged from th epcm the v2 will function properly but as soon as i plug the car in it cuts off.
    Sep 2003
    Just to clarify for me and to help you - What happens when V2 is plugged in by itself (not to the laptop) into the car's OBD2 port?
    Jun 2007
    the screen will not light up, but the little lights below the screen will cut on and stay on. the little orange, blue, orange, green lights stay lit. sometimes when you just plug it up to the car just the far little green light will stay lit, but still no activity from the v2.
    Aug 2004
    You didnt install the drivers correctly for the V2 unit. That is why you arent getting anything on the screen.
    Jun 2007
    Ok, so i geuss i own 2 bad cars. I hooked it up to a guys car at work and it works fine. So what would cause it to act like this on my car. Is it a short in the diagnostics port or something? When i plug it up by itself to my car the little lights stay lit and flicker, it's like it freezes up.
    Jun 2007
    Yes, i do own 2 bad cars, with the same problem. It was the cigarette lighter fuse. Now i can start screwing up my tune.
  1. dvt noob
    By blazinblue in forum General
    Last Post: January 17th, 2009, 12:37 PM
  2. noob needs help on what to buy
    By cajundragger in forum Gen III V8 Specific
    Last Post: December 21st, 2008, 05:03 PM
  3. Az Noob
    By azcatfan in forum Lounge
    Last Post: November 25th, 2007, 08:51 AM
  4. New Here = noob
    By blazinblue in forum Lounge
    Last Post: October 25th, 2007, 06:18 AM
  5. I'm a noob help!!
    By grump768 in forum Tips and tricks
    Last Post: July 20th, 2004, 02:46 AM
