Results 1 to 10 of 11
Thread: Allison 6spd .cal files (updated 25th July 2007)
    Exclamation Allison 6spd .cal files (updated 25th July 2007)
    Just added a new O.S to the supported list (8P6).
    Extract the zip in to the directory -
    Program Files\EFILive\V7\Calibrations\ALLB
    P.S - Remember you need to be running V2 Firmware FSProg_V2_4_60.ffw or higher to fix the TCM read errors encountered with earlier versions.
    New Member Slowride's Avatar
    Jun 2007
    Got it now after re-downloading it.
    "If you don't make dust, you eat dust"
    Jan 2006
    Works ok for me
    Lifetime Member DURAtotheMAX's Avatar
    Nov 2005
    doesnt work for me? says invalid or corrupted zip file?
    2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Jun 2007
    Dura,
    I should have been more specific. (invalid or corrupted zip file was the same error I was getting) I re-downloaded the file and re-associated it with my zip program. If you check the above file (right click it and left click properties) before downloading, it is asscociated with .php instead of .zip
    edit: here is a copy of the properties as it is:
    forum.efilive.com/attachment.php?attachmentid=1836&d=1183012174
    Here are the properties from another file posted on the site:
    download.efilive.com/software/EFILiveV742_527_660_646_58.zip
    May 2007
    so after i unzip that file with the two files in it i should be able to read and edit the 6 speed allison...correct?
    Mar 2007
    i don't know what i am doing wrong but i am not able to open the file also.
    Mar 2007
    yea i just figured it out. i changed programs i was using to unzip the file.
    Jul 2007
    ive been tryin to open this file for an hour and cant get it to unzip....im usin winzip.
    Jun 2007
    I ended up using 7zip (which is free dl @ cnet) to open the file.
    No clue why it would with it and wouldn't with winzip11.
    Haven't had the time to check.
    A zip file should be wham, bam, ty mam'
    There is definately a problem with the file just by viewing the posts that are having a problem opening it. My guess would be y'all have never had any problems before opening zip files.
  1. Updated EFILive - Can't Load old .tun files
    By VegasDMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 11th, 2010, 05:17 PM
  2. P12 supported vehicles & Cal files (Updated 20-Feb-2008)
    By GMPX in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: February 12th, 2009, 10:13 PM
  3. Updated Cal files
    By Alvin in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: July 29th, 2008, 11:07 AM
  4. July 22 2007 Software Update
    By SOMhaveit in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2007, 09:21 AM
  5. EFILive V7.4.2 Public Update - July 22, 2007
    By eboggs_jkvl in forum Lounge
    Last Post: July 23rd, 2007, 01:07 AM
