Results 1 to 3 of 3
Thread: idle problems
    Sep 2006
    Default idle problems
    will not start and idle if you don't rev a few times and acts the same warm or cold. also dies when you give a little gas then let off. I am in sd mode after the auto ve tune. 01 cpu 6.0 lq9 tr 224 cam 3000 stall ls6 intake and s&p headers. also which pid should I monitor to see narrow o2 switching.
    thanks Woody
    Jun 2005
    Engine>Idle>Start Up>Start Up Friction Correction Airflow
    Increase that table. I had to bump mine up 4~5 grams/second. You may need more or less.
    Nov 2006
    Quote Originally Posted by woody69
    Heated O2 Sensor Voltage Bank 1 - Sensor 1
    Heated O2 Sensor Voltage Bank 2 - Sensor 1
  1. Wierd idle problems
    By chrleb2 in forum Gen III V8 Specific
    Last Post: September 9th, 2008, 01:18 PM
  2. Idle problems after TB install
    By Dopey in forum Gen III V8 Specific
    Last Post: July 12th, 2008, 01:15 AM
  3. Idle problems can someone help me
    By 1meangto in forum Gen IV V8 Specific
    Last Post: August 9th, 2007, 11:41 AM
  4. Problems with idle after AutoVE flash (again)
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: October 4th, 2006, 03:17 PM
  5. Steering bogging/idle problems
    By Haans249 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 10th, 2006, 04:46 PM
