Results 1 to 10 of 11
Thread: How do I stop the auto replotting...?
    Default How do I stop the auto replotting...?
    When viewing the Scan tool dash charts,
    I want to replot manually when I'm ready,
    so how do I prevent the automatic replotting that happens
    every so often while I'm still setting up the charts...?
    Set Properties->Playback->Auto replot limit to a very small number.
    Any log file with more frames than what you specify will not replot automatically. You'll just get an annoying "Do you want to replot now" request each time EFILive thinks it needs to replot.
    You can switch off that annoying replot request by disabling confirmation dialog boxes in Properties->Options->Disable confirmation dialogs. But that will disable them ALL and you may end up losing data because you close a window without saving something and you will not be prompted to save it.
    Sep 2003
    did you mean less?
    If I set the re-plot number to 100k frames anything less than 100k will not be autoplotted. Maybe I am misunderstanding something.
    My wording was confusing.
    If the log file has less frames than the value in Properties->Playback->Auto replot limit then it will autoplot without prompting the user.
    If the log file has more frames than the value in Properties->Playback->Auto replot limit then it will prompt the user to see if it is ok to go ahead and do the replot.
    so by setting that value very small (say 10 frames) - you will ALWAYS be prompted whether or not you want the charts to replot, for example when you make changes.
    Paul,
    Thanks (as usual, stellar service and support).
    Joe
    :2-thumbs-up:
    Suggestion:
    Entering a value of zero means "do not automatically replot and do not prompt" (i.e. allowing user to manually replot when user is ready).
    Suggestion:
    It is a good idea. Although I would prefer to add a checkbox next to that setting with "Prompt when replot needed?"
    Yes, a checkbox is very much better.
    (...us software types are maybe too comfortable with having zero mean something special...).
    Joe
    :2-beer-mugs-chinking:
    Aint that the truth?
    Also, he he he, we think in hexadecimal more than we do in decimal...
    :lol: :lol:
  1. How to stop C0245 & C0121 DTC
    By hhorton in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 06:38 AM
  2. Engine won't stop fueling
    By roadkill81304 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 17th, 2008, 06:25 PM
  3. After Stop Idle Issue
    By Dennis93TA in forum Gen III V8 Specific
    Last Post: November 8th, 2007, 10:34 AM
  4. Surging When coming to a stop- 10 MPH only
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2007, 10:27 AM
  5. Surging when coming to a stop
    By 12secformula in forum Gen III V8 Specific
    Last Post: December 18th, 2006, 02:01 PM
