Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Thread: Mileage Increase on Trucks
    Apr 2007
    Default Mileage Increase on Trucks
    What have you guys been seeing for a fuel mileage increase on the full size trucks and SUV's? I have an 01 Yukon XL, 3" lift, 325/60R18's, 3.73's and I am seeing right around 16 now. I haven't done a comparision to the stock cal in a long time, but I thought it was around 14 to start.
    Also, i put it on the dyno here at work and got 252 hp and 279lb ft. Not to bad for an intake and cat back.
    Jan 2007
    With my 2000 5.3 ext cab Since Ive lowerd O2 switch points and added some timing based off the optimal timing table I can get about 21-23mpg crusing at 45-60 and about 17-20 avarage city/hyw.
    So far Ive probably got on avarage about 2-3mpg more especially on cruises.
    Mar 2008
    Quote Originally Posted by cmitchell17 View Post
    When you say you added timing, what do you mean, could you help me out a little. I am tuning my step dads truck for better economy.
    Tony
    Jan 2007
    So far I havent noticed anything from adding timing in part throttle non pe.
    You can experiment with it but I don't think it will help.
    I think the factory timing would be the best timing, except the timing in PE high throttle beucase the stock tune is always consiveritive in the high load regions.
    Aug 2005
    You might not feel it seat of the pants, but a load bearing dyno definitely shows a worthwhile power gain at part throttle.
    Justin
    Jun 2007
    I have a 1999 5.3 ext. cab, and I lowered my O2 switch points to:
    CL Mode Bank-1 Bank-2
    0 460.015667 460.015667
    8 460.015667 460.015667
    16 460.015667 460.015667
    24 460.015667 460.015667
    32 460.015667 460.015667
    40 465.000356 465.000356
    48 469.985046 469.985046
    56 475.003646 475.003646
    64 479.988336 479.988336
    What did you set yours at cmitchell17?
    Aug 2005
    Quote Originally Posted by n6oli
    Drop the CL Mode 0,8,16 to something quite a bit lower... 250-300mv and you should see a slight improvement. Your table is still richer than 14.7:1 across the board (450mv).
    Jun 2007
    Could you copy with labels from your tune, and then paste in a message what you have yours set at?
    Sorry, I didn't see who sent the message. I thought you were cmitchell17?
    Jun 2007
    Why does GM have the O2 switch points set so high in their tunes?
    This is the factory switch points.
    LABELS bank
    0 480.022245 480.022245
    8 480.022245 480.022245
    16 480.022245 480.022245
    24 480.022245 480.022245
    32 480.022245 480.022245
    40 480.022245 480.022245
    48 489.991625 489.991625
    56 509.998203 509.998203
    64 520.001492 520.001492
    Jan 2007
    Hey mine are:
    372.495363 372.495363
    373.343100 373.343100
    375.208120 375.208120
    380.565813 380.565813
    450.012377 450.012377
    Let me read up on Dc Justins post to see what he said to do.
  1. Sudden increase in Air/Cyl
    By Mileage in forum E37, E38 & E67 PFI ECM's
    Last Post: June 9th, 2009, 11:09 AM
  2. Cranking VE, generally increase/decrease?
    By efizjb in forum Gen III V8 Specific
    Last Post: April 11th, 2009, 12:29 PM
  3. LBZ defuel/rpm increase progress?
    By Cobra#3747 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 7th, 2007, 11:34 AM
  4. program for gas mileage?
    By trook in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 27th, 2007, 09:46 AM
  5. fuel pump prime - increase time?
    By 350SS in forum General (Petrol, Gas, Ethanol)
    Last Post: April 8th, 2007, 09:06 AM
