Results 1 to 4 of 4
Thread: Reduced engine power
    Jun 2007
    Default Reduced engine power
    I'm currently tuning a 2004 silverado SS with a vortec SC. tuned pretty decent with 8 psi of boost. Install a smaller pulley and when I try pulling it on the dyno I get a reduced engine power code. I seen 12psi of boost right before the code. I'm used to using HP tuners where you just extend the maf table with higher boost and your good to go. I'm taken some advice from other posts and increased some of the map tables but no luck. Any ideas? do I need to upgrade to COS3? if so what is involved?
    Dec 2005
    i am guessing you rased predicted airflow tables up
    Jun 2007
    yeap I increased the values in that table.
    Junior Member Turbo595t's Avatar
    Sep 2005
    Quote Originally Posted by redlinepd
    What codes did you get?
    I would rather be Blown, then bottle fed
  1. reduced engine power can't be shut off
    By 496chevy in forum Custom Operating Systems
    Last Post: May 31st, 2009, 01:02 PM
  2. P1514 Reduced Engine Power.
    By Mort in forum Gen III V8 Specific
    Last Post: April 2nd, 2009, 12:51 PM
  3. Reduced engine power after autoTune
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 07:08 AM
  4. SD mode = reduced engine power
    Last Post: February 18th, 2006, 12:19 AM
  5. Reduced Engine Power while MAFless
    Last Post: December 20th, 2005, 04:08 AM
