Results 1 to 9 of 9
Thread: stream
    Apr 2007
    Default stream
    Hey there.
    I just got EFIlive a while ago and want to use it on my buddie's vortec. Do I have to do anything to activate the stream before trying to tune it?
    I already used a liscense and dont want to accidently waste the other one.
    thanks
    I have version 7.4.2
    Oct 2004
    The Stream licenses enable unlimited tuning of specific PCM/TCM controllers. I suspect you simply want to use a VIN license. If you have allocate one to this vehicle already it will not use another. If you need another they cost US$99 each.
    Andrew
    EFILive Crew
    Apr 2007
    Default sorry, I'll be more clear
    What I was referring to is the fact EFIlive allows tuning of any 98' vortecs for free via a supplied stream license. I was just curious if I had to activate said stream in some way as this info wasn't listed in the sticky on this board. And i have not yet tuned this vehicle.
    thanks
    Oct 2004
    Free 97/98 tuning is only for the LS1A Stream. This is a carryover from what was offered in FlashScan V1. 97/98 tuning of vehicles not included in the LS1A stream (Corvette and Camaro basically) will require a license per vehicle.
    Andrew
    EFILive Crew
    Apr 2007
    Default Oh
    I was told that, that included the vortecs. Well thanks for clearing that up then.
    Nov 2006
    make sure you have the 97/98 stream!
    my V2 didn`t come with it and i had to get the license code.
    Apr 2007
    Default how
    how do i check that?
    Oct 2004
    - Connect FlashScan V2 to your PC/Laptop
    - Open the Tune Tool
    - Go to the 'Help->FlashScan V2 VIN Licensing' menu option
    - Click on the 'Streams Licensing' tab
    - S-LS1A (97/98 LS1) should be active
    Andrew
    EFILive Crew
    Apr 2007
    Default thanks
    thanks
  1. stream upgrade
    By dags in forum Purchase and Shipping
    Last Post: April 26th, 2010, 07:45 PM
  2. LS1-A stream free?
    By joshp14 in forum FlashScan V2
    Last Post: January 10th, 2010, 08:54 AM
  3. Stream question
    Last Post: January 1st, 2010, 01:13 AM
  4. no data stream
    By markhyma in forum EFILive V4
    Last Post: November 6th, 2008, 08:01 PM
