Results 1 to 8 of 8
Thread: flash over hp with efilive
    May 2006
    Default flash over hp with efilive
    Quote Originally Posted by mr.prick
    IMO let them do what they do, and do some tweaking of your own later.
    or why bother having someone else tune the car?
    it also might not be a good idea to let them "experiment"
    with your car and a tool they are not familiar with.
    i have had bad tunes by people using "other" programs and either they had no
    idea what they were doing or the tuning tools they used where inferior.
    just my opinion but be careful because it sucks to drop good money
    on a crappy tune and find that you could have done a better job yourself.
    you having efilive already, gives you the ability to check they`re work
    but gives you little comfort after spending your money.
    IMO
    after reading this it sounds like i can put my old pcm back in the car and tune over the hp tune that is in it i was told (by the A$$ that tuned my car) that they would not work together and fry the pcm which is correct also can could efi to flash over any others ie. hypertech
    2002 ws6 stock short block
    GMPP cnc LS6 Heads 11.4:1 cr
    .576 i .581 e 116 lobe
    D1SC @ 10#
    723 rwhp 654 rwtq on E-85
    May 2006
    anyone
    D1SC @ 10#
    You should be able to flash over it, if it's not locked.
    May 2006
    thank you wish i would have known that sooner
    D1SC @ 10#
    If it's an HP custom tune, then make sure you write over it using full flash.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Don't they use a different seed with their custom tune? If so, you won't be able to flash over it using EFILIVE.
    Dave.
    Nov 2006
    make sure you save the tune before you reflash just to have it,
    even if it is not the best tune.
    Quote Originally Posted by Biggsy
    Oh, they're locked...? Then he would need to first find out what the seed is from his tuner.
  1. Can EFIlive be used to flash a new PCM??
    By zapp168 in forum Tips and tricks
    Last Post: August 29th, 2014, 09:15 AM
  2. Can't flash
    By cmitchell17 in forum Duramax LLY
    Last Post: May 11th, 2010, 02:31 AM
  3. Pre Full Flash to Full Flash Tune Question
    By Donovan in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 13th, 2010, 11:43 AM
  4. Can i flash my VIN in a used PCM?
    By mvvette97 in forum Gen III V8 Specific
    Last Post: September 17th, 2007, 11:23 PM
  5. Flash scan + efilive 7.0
    By 2000ssnb in forum General (Petrol, Gas, Ethanol)
    Last Post: November 21st, 2004, 10:00 AM
