Does anyone know if it is possible to use EFI to control a Meth/Water injection system, or a way to make it happen??
'07 LBZ Classic, BW S464 Turbo, EGR deleted, 3" IC piping, Trans-go, ATS 5-star converter, stock clutches
As far as I know the EFI Live Scan program doesn't. I am sure the module could use the discrete pins as outputs as well in inputs but that is only possible with two things:
A The reflash of the onboard firmware to support this. It would have to take data from in from the USB cable and flip the direction of the discete pin and turn it on or off. This would be based automatically by a PID or manually by a checkbox.
B A rewrite of the EFI Live software to support the sending of data to tell the V2 module to do this.
Sounds like a lot of work. Don't know if Blacky is up for that. hehe. Sounds like you could do a lot of fun stuff with that though. If only I could program Inferion processors.
Right now we can do it with an LB7 or LLY but not the LBZ.
As soon as Team EFILive gets to the LBZ custom OS item on their "to do" list, I'm sure it will be made available.
www.socaldiesel.com
EFILive-DSP5......Switch your Attitude!
EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
EFILive-DSP4......Switch Your Colorado and Canyon Too!
