Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: LC-1 and FlashScan
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Default LC-1 and FlashScan
    Has anyone used an LC-1 WB with FlashScan yet? Has anyone seen a write up on the best way to hook it up. I just got mine today and after looking at the directions I can tell Innovate does not have a very good Tech Writer. I also want to do the SD tuning and already have a program setup to start it as soon as I get it installed.
    Thanks,
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Default Re: LC-1 and FlashScan
    Quote Originally Posted by BowlingSS
    Thanks,
    Bill
    You managed to get one!!, looks like the are B.O'd until mid June :cry:
    If the manual comes in a pdf file or something then please forward it onto myself or Paul so we can take a look.
    Nov 2003
    They do not send the doc on a pdf, just a hard copy. I can fax it to you on Tueasday if you send me your fax number.
    Just checked their web site and they do have a manual on pdf. Here is the link:
    http://www.innovatemotorsports.com/support/download.php
    Bill
    Bill
    The link was just fine, thanks Bill.
    May 2005
    I just ordered a flashscan and a LC-1, I would be intrested in seeing any info on this combo.
    Nov 2003
    Any news yet? Do I use the LM-1 PID?
    Bill
    According to the PDF document on the LC-1, the factory programmed settings for the second A/D output (the first is a narrow band simulator) is as follows:
    less tha 0.5 volts is while the LC-1 is warming up or error condition
    0.5V = 7.35 AFR
    5.0V = 22.3881 AFR
    So the formula you need to use in the calc_pids.txt file is:
    AFR = (({EXT.AD1}-0.5)*3.3418)+7.35
    If you can confirm that those settings work correctly with your LC-1, then we will add them permanently into EFILive.
    To use your LC-1, your calc_pids.txt file should look like this:
    Code:
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter  Value            Description
    VERSION     7.1.1            File version
    DECSEP      .                Decimal separator used in this file
    # Units
    *UNITS
    #Code     System     Abbr     Description
    # Add slot definitions here
    #Units             Low          High      Fmt  Expression
    *CLC-00-001
    V                  0.0          5.00       .1  "{EXT.AD1}"
    AFR               10.0          18.0       .2  "(({EXT.AD1}-0.5)*3.3418)+7.35"
    *CLC-00-002
    factor             0.0           2.0       .1  "{CALC.AFR_LC11}/{GM.AFR}"
    *CLC-00-003
    V                  0.0          5.00       .1  "{EXT.AD2}"
    AFR               10.0          18.0       .2  "(({EXT.AD2}-0.5)*3.3418)+7.35"
    *CLC-00-004
    factor             0.0           2.0       .1  "{CALC.AFR_LC12}/{GM.AFR}"
    #Code                      PRN  SLOT         Units            System           Description
    CALC.AFR_LC11              F001 CLC-00-001   "V,AFR"          Fuel             "Wide Band AFR 1 - LC-1"
    CALC.BEN_Lc11              F002 CLC-00-002   factor           Fuel             "Base Efficiency Numerator 1 - LC-1"
    CALC.AFR_LC12              F003 CLC-00-003   "V,AFR"          Fuel             "Wide Band AFR 2 - LC-1"
    CALC.BEN_LC12              F004 CLC-00-004   factor           Fuel             "Base Efficiency Numerator 2 - LC-1"
    Lifetime Member mistermike's Avatar
    Dec 2003
    I've got a pair of LC-1's on the way and the bungs are going in next week. If someone doesn't beat me to it, I'll compare the results to the LogWorks indication.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Member ace68's Avatar
    Jun 2004
    # File details
    *FILE
    # Units
    *UNITS
    *CLC-00-001
    *CLC-00-002
    *CLC-00-003
    *CLC-00-004
    Back to top
    That is what I was looking for I knew the cut and past job I did earlier was wrong.
    I will try it tomorrow and let you know how I make out.
    Jun 2004
    WOW! That’s awesome thanks man I just cut and pasted your PID info into the user-pid and bam, info came right up. However, you must use the second analog output from the LC-1 not the first one the correct 0-5 volt rang is on the second output. On my unit it was the green wire to the flashscan neg. connection and the brown LC1-1 out wire to the positive side on the flashscan.
  1. V2 flashscan with LM1
    By Xtnct00WS6 in forum FlashScan V2
    Last Post: June 6th, 2008, 11:50 PM
  2. LC-1 with Flashscan for 98s
    By dlandsvZ28 in forum General
    Last Post: August 24th, 2005, 04:44 AM
  3. Will flashscan
    By mgarfias in forum General (Petrol, Gas, Ethanol)
    Last Post: December 2nd, 2004, 04:27 PM
