Hi Guys!
While logging with my PLX SM_AFR WB02, instead of it giving me the varying voltage readings (0-5v=10-20AFR), it's giving me a flat 3.5v. Has this happened to any of you before and if so, could you Please tell me how you fixed it?
I have the SM-AFR+DB5 (gauge) combo and the gauge still registers the AFR. It doesn't stay at one certain reading, it works as it should.
Thanks in advance!
