Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Maps and pids....
    Jun 2005
    Default Maps and pids....
    I get asked often what to log and what to map out in the scanner. Attached below are copies of my MAPs and PIDs folder. Have at it folks...
    Maybe a few others could post up their stuff and we could drop this in the stickies???
    **EDIT** Due to tech. diff. with the upload feature, I had to change the extension on the attached files. They are .zip files. Right click, save target as to your hard drive. Then, change the extension to maps.zip and pids.zip and it should work.
    Feb 2007
    I think this would be an excellent sticky!
    Thank you, SSpdDmon! This is fantastic.
    EDIT: I pulled the comment Beer99C5 quotes (while he was typing!) because I realized you'd alread identified them! I think some guidance as to which logically work together might be helpful (some were obvious to me but only because I have been staring at this stuff for months now and I'm starting to get it. ) A "library" of useful components on forum, along with some very brief helpful hints would be a tremendous supplement to the tutorials and would assist people (myself included) in finguring out how to figure stuff out!)
    2004 Pontiac GTO - Quicksilver/red/m6
    1-of-344
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Quote Originally Posted by gto_in_nc
    I think this would be an excellent sticky! Perhaps some more knowlegable than I can create several flavors? Such as "VE-centric", "Looking for Lost Spark", "Chasing Economy", a shotgun "I need to ask for help!" set, etc.
    X2
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Oct 2006
    Didnt work for me.... Maby im stupid??? excel wont open it...
    Jul 2006
    Default They are Zip files
    Quote Originally Posted by SSpdDmon
    Rename them w/ .zip
    Maine USA
    Feb 2007
    Quote Originally Posted by Beer99C5
    Rename them w/ .zip
    And then copy them from the ZIP to some other folder. (Scan tries to open the ZIP files themselves rather than view them as compressed folders...)
    Oct 2006
    still confused... I hate thes computer shit!!!
    Feb 2007
    When you click the attachments in SSpdDmon's post above, it probably asks if you want to open or save. Say "Save". When you save, either save them as Excel spreadsheets (with the .XLS extension) and then rename them to have a .ZIP extension, OR you can do the rename in the same step as the "save".
    The problem is that the files aar ZIP files but the forum doesn't allow uploading ZIP files. SSpdDmon got around this by pretending they were Excel spreadsheets...
    Make sense so far?
    Feb 2007
    Then, after getting them saved as ZIP files, you will need to extract the contents from them because ScanTool doesn't know how to look inside a compressed folder. If you have a modern operating system, you can probably browse into the ZIP files and then just copy & past or drag & drop. If an old OS on your computer, you may need something like WinZIP to open the ZIP files.
    Follow me?
    Oct 2006
    Follow me?
    Yes I just got it.. saved as a zip, opened the scanner and moved the zip files to the scanner map files folder and it worked... Then opened it... thanks sspdmon...
  1. editing and saving PIDs / MAPs, VDPs
    By ZL1Killa in forum Gen III V8 Specific
    Last Post: April 7th, 2009, 04:41 AM
  2. E38 SD PIDs and MAPs
    By JezzaB in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2008, 02:10 PM
  3. Maps
    By limited cv8r in forum EFILive V4
    Last Post: August 6th, 2007, 09:26 AM
  4. Is 7.2.3 going to have more MAPS?
    By BowlingSS in forum General
    Last Post: August 10th, 2005, 03:30 AM
  5. Replies: 0
    Last Post: December 13th, 2003, 09:24 PM
