Results 11 to 20 of 29
Thread: Maps and pids....
  1. #11
    Jun 2005
    Thanks gto...
    If you have questions about why I made a certain map, let me know. The main ones I wanted to share are the ones that plot out spark, kr, fuel trim tuning (MAF, VE, and IFR), and WB tuning (MAF, VE, and IFR). Using the software to log the right stuff is only part of the battle. If you can't analyze the data you logged correctly, you're just spinning your wheels.
    If I'm feeling generous this weekend, I'll try and post up the filters I use too.
  2. #12
    Oct 2006
    Quote Originally Posted by SSpdDmon
    Thanks gto...
  3. #13
    Lifetime Member Chalky's Avatar
    Sep 2003
    Thanks for sharing. Couldn't get Fuel Efficiency.map open.
    2015 Z06 A8
  4. #14
    Jun 2005
    That's using the custom pid from the mpg thread on here. It may not work if you don't have that pid setup.
  5. #15
    Sep 2003
    What pids do I need to get th MPG pid to function?
    2015 Z06 A8
  6. #16
    Quote Originally Posted by Chalky
    On the PIDs F8 tab, on this pid right click->More Info and you will see which other PIDs it requires.
  7. #17
    Jun 2005
    SAE.VSS - GM.INJFLOW - GM.IBPW1 - SAE.RPM
    **I think it assumes your IFR table is accurately populated.
    You'll also need a calc_pids.txt that has the MPG pid in it.
    It should be under My Documents>EFI Live>V7>User Configuration.
  8. #18
    Oct 2006
    sspdmon, what map do you need to dial in the MAF???
    THX...
  9. #19
    Jun 2005
    WBO2 Correction vs MAF Hz
    You'll need to change the data tab in the map properties (Ctrl+Enter) so that your WB's Base Efficiency Numerator is the parameter being referenced. You can save the map after changing it the first time and it should work from there on out...
    The WB maps have 3 versions:
    1 - WB AFR (will show you the average, high, and low readings from your WB sensor)
    2 - WB Commanded (will show you the average, high, and low AFRs commanded by the PCM)
    3 - WB Correction (will show you the average, high, and low BENs calculated by the scanner)
    Remember:
    Correction = WB AFR / Commanded AFR
  10. #20
    Sep 2003
    Remember:
    Jeff:
    Can you give me a little more detail on how you setup this MAP/MAPS?
    2015 Z06 A8
  1. editing and saving PIDs / MAPs, VDPs
    By ZL1Killa in forum Gen III V8 Specific
    Last Post: April 7th, 2009, 04:41 AM
  2. E38 SD PIDs and MAPs
    By JezzaB in forum E37, E38 & E67 PFI ECM's
    Last Post: March 2nd, 2008, 02:10 PM
  3. Maps
    By limited cv8r in forum EFILive V4
    Last Post: August 6th, 2007, 09:26 AM
  4. Is 7.2.3 going to have more MAPS?
    By BowlingSS in forum General
    Last Post: August 10th, 2005, 03:30 AM
  5. Replies: 0
    Last Post: December 13th, 2003, 09:24 PM
