Results 1 to 7 of 7
Thread: Probably a Dumb question...............
    May 2006
    Default Probably a Dumb question...............
    Can I use the EfiLive V1 Scan Tool to scan codes on a 1999 Ford Escort? It has OBDII so I thought that I'd ask.
    Thanks Guys!
    Wink Not a dumb question
    V1 uses the same physical protocol as GM...
    GM uses SAE J1850 VPW (Variable Pulse Width Modulation),
    Ford uses SAE J1850 PWM (Pulse Width Modulation).
    Ford protocol is different than GM, so the answer is "No".
    More info:
    http://www.obdii.com/background.html
    http://www.cardlabs.com/CardLabs_obd2.htm
    May 2006
    Thank You Sir! I guess it's back to the paper clip trick!
    Quote Originally Posted by FreddyG
    If you go to AutoZone or equivalent, they have loaner scan tools...
    get a loan of the scan tool that reads codes and monitors sensors...
    May 2006
    I didn't know that! Thank You again for the info!
    Jan 2007
    Can't you use Autotap with the older V1 cable?
    May 2006
    Thanks! I Appreciate the advice!
    We just bought one of those cheap scanners from Harbor Freight and it did the trick.
  1. Dumb question...
    By 8100 Power in forum FlashScan V2 BB Logging
    Last Post: September 30th, 2008, 04:56 PM
  2. New guy, dumb question
    By Pipeliner in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 14th, 2007, 08:20 PM
  3. Dumb question...
    By Cougar281 in forum Vortec V6/V8 Specific
    Last Post: November 7th, 2007, 09:55 AM
