Results 1 to 10 of 11
Thread: correct me if i'm wrong...
    May 2007
    Default correct me if i'm wrong...
    PLEASE!!! Hooked the LC1 up to see if i could do an auto ve. if i post a log can you guys tell me if my wb looks to be working right and anything i need to do different. thanks
    Jan 2005
    Something isn't right. There are a bunch of spikes in the LC1 data with no apparent cause. The question is-- are things really going lean, or is there a bad connection in the LC1 wiring.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Ditto.
    Noisy signal... does the cable run close to the spark wires...?
    Or bad/noisy ground connection.
    May 2007
    it doesn't run real close to the wires...but that can easily be fixed i guess...and yes it prolly has a bad connection on the lc1 wiring. i just kinda threw it on to try it out. i've been dyno tuned before so the a/f isn't actually that shakey.
    what about my ve map? numbers aren't supposed to be that big are they?
    Lifetime Member Doc's Avatar
    Oct 2005
    Ditto noisy ground
    System ground, analog ground, goto the Data port ground
    Heater ground, best location I have found on a hardwired LC-1 unit is the back of the head.
    On my portable LC-1's it varies by the vehicle for a clean, appropriate, accessable heater ground location.
    www.efialchemy.com
    www.greatamericancarwar.com
    Lifetime Member mistermike's Avatar
    Dec 2003
    Once the wiring is tidied up, compare the AFR indication in EFI Live to that in LogWorks to see that they're reading the same. Key on, engine off will give you a stable steady reading once the engine has been run.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    May 2007
    guys i can't figure this thing out at all...tried again today, got the sensor plugged in and then everything hooked up, turned on the laptap started logging, looked ok idling around 13.xx(i just put a cam in) then i went to calibrate the sensor(touch the black wire to a ground)and the reading went to 25.xx af with like a 6.2v reading...i got mad and walked away, came back after awhile, fired it back up and the reading was back down to 13.xx with like a 2.Xv reading...there are no changes in a/f reading with movement of the throttle...i'm so confused, as i'm sure most of you will be by the time you're done reading this post
    Feb 2007
    Are you doing a free-air calibration or are you grounding the black wire with the sensor in the exhaust shortly after running the engine?
    Also, are you still seeing the jittery output you posted before? That was almost certainly a poor signal ground.
    2004 Pontiac GTO - Quicksilver/red/m6
    1-of-344
    Oct 2006
    Free air calibration should be 20.9-20.8 , and you can't do it the exhaust after running engine it has to removed from bung and in free air .
    Like someone else said LogWorks will show a lot of info , start LogWorks right after turning key on and it should show percentage of heater function and then AFR after heater has reached temp .
    Ground to the block if at all possible .
    2006 Trailblazer
    Dec 2003
    I've used an electric leaf blower to clear out the exhaust for calibrating. Seems to work pretty well if you have a H or Y pipe.
  1. How to correct WOT for each gear?
    By PRAY in forum Gen III V8 Specific
    Last Post: June 9th, 2008, 09:00 AM
  2. 2 BAR - LS2 - Kpa Correct MAPv-Not
    By SBTuner in forum Gen IV V8 Specific
    Last Post: November 28th, 2007, 07:09 PM
  3. Is this map correct?
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: January 19th, 2007, 02:22 PM
  4. WHat is the correct timing?
    By Mike :) in forum General
    Last Post: June 15th, 2006, 02:42 PM
