Results 1 to 4 of 4
Thread: Which one to Tune
    Senior Member Naf's Avatar
    Aug 2006
    Question Which one to Tune
    Dear All,
    I have a question to ask...I am about to initiate my first official project.
    My project will include changing the Cam, Headers, Exhaust system, Intake manifold CAI and other little jobs, but ultimately leaving the long block alone...
    Installin the parts for me is the simpliest task. But when it comes to Tuning i am totally lost...I understand the Maps and the logs but i am unable to peice them together..Lack of Tunin schoolin for me, Even though i have one of the largest libraries on tuning...
    Anyways my question...If i were to keep the shortblock the same, and only bolt-on the above mentioned parts, Should i alter the VE or MAF?
    I have a tuner here, and he does everything from the MAF, leaving the VE the same...
    Should i follow in his steps, or should i actually sit there and LOG Autove, decode the log, adjust the map and try it all again?
    I was one of the fooled whom bought the V2, which is lost in my junk pile, but i am startin to get use to my V1...I like the BEN factor maps, and used them a bit, but incorrectly.
    Looking forward to your replies about which map to alter, the MAF or VE
    Thank you for your time
    BR
    Naf
    My opinion: start with VE table (after recalculating IFR table); it will mean reading/following the AVE tutorial, but that may help to tie the logs/maps together, and the process teaches you how some of the fueling tables work; I assume you have a wideband O2 sensor.
    Lifetime Member Doc's Avatar
    Oct 2005
    Take the high road.
    www.efialchemy.com
    www.greatamericancarwar.com
    Aug 2006
    Widebands are the min...I prefer AEM UEGO rather than the Innovative LC-1.
    The calibrations needed are minimal and they are simpler to install with plenty of wire for custom installations...
    Ok...Take the high road, so AutoVE...then MAF calibration..
    There is a simplier road, Roadrunner...But i need to off-load this V2, close to cost, so i may get the Road Runner instead...
  1. Replies: 5
    Last Post: August 5th, 2008, 02:35 PM
  2. Tune VE and MAF tables or leave VE stock and tune MAF only
    By BlackGMC in forum Gen III V8 Specific
    Last Post: August 4th, 2008, 08:05 PM
  3. What else can I tune without scanning or black boxen it? Tune history inside.
    By Round Rock TJ in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2007, 02:27 AM
  4. Convince me to change to a 2bar tune...709rwhp through an EFI maf tune.
    By onfire in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: June 16th, 2006, 12:04 PM
