so would it be possible to flash the 08 z06 with the ls3 os?
I guess so, I suspect the Z06 development was done before that new OS came out. I'd say if GM do an update to the 08 Z06 it will be to an OS with the new MAF table.Originally Posted by redhardsupra
What I have not had a chance to do is go over the code entirely to see if there is still a flow limiter in there. I suspect there might be. The only reason the table changed in the new 08 is they modified the maths behind the table that allowed larger numbers. Perhaps they did this with the idea the future LS engines will one day have factory forced induction.
