Page 3 of 3 FirstFirst 123
Results 21 to 21 of 21
Thread: 4l80e TCC problem
  1. #21
    Aug 2006
    Thanks joecar, I got the scan tool and tuning tool on the same page. I can track the correct cell now. I got some adivse to try raising the timing in the areas with knock. It worked! I put the stock timing table back in, then began to add timing in the areas that were problems. Between adding timing and removing fuel it fixed the knock pretty well. I still get a little bit, but it is in isolated cases now and nothing like the knock I was getting before. I re-scaled the injectors again, correctly this time. The MAP sensor is scaled, and my VE is being touched up right now. Thank you all for the help, I have learned a lot in this diagnosis.
  1. 4l80e 4th gear and tcc problem (running from 4L60E segment)
    By kkustomz in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 28th, 2011, 02:05 PM
  2. 4L80E TCC problem
    By Arnoldi in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 19th, 2010, 11:26 AM
  3. 4l80e help
    By da69fishman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 10th, 2008, 12:21 AM
  4. L76 4L80e AFM
    By 4wheelin in forum E37, E38 & E67 PFI ECM's
    Last Post: November 24th, 2008, 11:04 AM
  5. 4L80E 4rth Gear problem
    By almusafir in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 14th, 2007, 02:43 AM
