I'm adding a few connectors to my bench harness. I've gotten the pinouts for the 98 LS1 (97 seems to not be an LS1 style PCM), and the 99-07 LS1. It appears that the pinouts relevent to a bench harness are the same for both the 98 and the 99-07 EXCEPT the grounds... on the 98 21 & 60 are grounds, and on the 99-07 1 & 40 are grounds. On the 98, 40 is empty. Ideally, I'd like to make the connector work for 98 and 99-07 LS1's. Can pin 40 on the 98 PCM be used for ground?
Edit: It appears that the pinout for the LB7 is IDENTICAL to the 99-07 LS1. Can anyone confirm that for me?
