Red,
Here's the lastest 86lb low imp tune.
Red,
I found this out tonight as well. I got the PW's down to 1.5mS and saw high teens and low twenties on the WB for decel. I bumped it back up to the mid 1.7's now and it's better. Going to target a 1.7ms PW and see what that does.Originally Posted by TAQuickness
http://www.picotech.com/auto/tutoria...injection.html
take a look at this. injector voltage and current graphed as a function of time on a working injector. this would give us the offset/open/close times, and probably gives us an idea on the shape of the IFR curve for the closing phase.
anyone's got a scope to try this out?
oh this is even better, they actually chop up the fueling stages just like I did, maybe I'm onto something here:
http://www.lindertech.com/newsletters/nwk7~03.pdf
and another one:
http://www.automotivetestsolutions.c...rWaveforms.htm
I have a scope and if anyone want's to show up at my place in West LA, we can have a look and post the results.Originally Posted by redhardsupra
Ira
can't you just hook it up to your car and see what the waveforms look like? it would be really nice to have few different kinds to compare, like lucas, ford/bosch, gm stockers, holly...
do you have some 'official' data on the injectors? are they the racetronix ones or something else (rceng?)Originally Posted by onfire
what fuel pressure do you run them at? do you have a manifold referenced regulator? does your fuel pressure drop off at higher boost/rpm?
48 base psi. Boost referenced only 1:1 . Twin Bosch 044's so there's zero fuel pressure drop...when I was running Mototron 60's I had the base pressure at 74psi ramping up to 91psi....the pumps are now laughing at a base pressure of 48...
Jeff:Originally Posted by SSpdDmon
Any update? For those of us running the SVO 30's, I wonder if another injector would not work better to address idle issues. Maybe something with lighter internal parts that would respond quicker to minimum IPW's.
2015 Z06 A8
