Results 11 to 20 of 24
Thread: Any way to unlock LS2 edit vehicles?
  1. #11
    Jun 2006
    What are the different types of locks you might encounter. For instance.. if it isn't a seed lock what can it be?
  2. #12
    I don't really know, seed/key is the most effective.
  3. #13
    Oct 2006
    i was hoping to hear a response like your last comment in reguards to these pcms. thank you very much for the info man. Greatly appreciated.
  4. #14
    Jun 2007
    Well now I am having the same problem with still no solution. If I can find out the ls2 edit seed key will efilive unlock it? Well I have used ls1 edit a few times and have talked to the guys there before so I just sent them a email to see if they will help us out in any way.
    cosmos purple 2004 gto
    408 E85 GT47-91 ,turbo 400,9" currie straight axle,28/10.5w mt et streets
    2005 yellowjacket gto
    417 rwhp and 397 torque
    582 rwhp and 676 torque (150 shot)
  5. #15
    Quote Originally Posted by 1meangto
    Yes I believe so, although you only need to supply the EFILive unlock software with the key value. The seed value is ignored when locking/unlocking. The seed value is only used when the controller is not locked.
  6. #16
    Jun 2007
    Thanks and here is the answer I got from ken.
    Mike,
    The current LS2-edit locks by default, But the tuner can check a box
    to not lock the file. We are working on a release that will unlock by
    default and make the programmer select lock if needed. The default
    setting has caused problems were tuners don't realize they are locking.
    Any LS2-edit tuner can unlock the E40 ECM.
    Ken
  7. #17
    Ken
    ??, perhaps not worded correctly? 'ANY' LS2Edit tuner?
  8. #18
    Jun 2007
    Quote Originally Posted by GMPX
    Yeah that doesn't make a whole lot of sense does it. Well they would not give me the key to unlock it so I'm assuming it cannot be done with efilive. But I did get the ecm unlocked by the original tuner today and yes I can read the tune!!!!
  9. #19
    Perhaps the reason Ken did this was not to stop other LS2Edit users from downloading others programs but to stop the ECM's getting programmed by the dealer? If any Edit user can unlock it I can't see it being a complex process.
  10. #20
    Jun 2007
    Yes this is why he said he did that in a later email. But he also said a tech 2 will overwrite the lock so theres no point in the lock.
  1. How can I unlock a PCM
    By imtduncan in forum Gen III V8 Specific
    Last Post: February 19th, 2009, 08:12 PM
  2. Can't unlock pcm
    By red12secz28 in forum Duramax LB7
    Last Post: November 30th, 2007, 02:29 AM
  3. How do I unlock the PCM?
    By -=Mod=- in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2007, 12:06 PM
  4. Unlock the PCM
    By ASSAMI in forum RoadRunner Real-Time PCM Emulator
    Last Post: February 15th, 2007, 05:49 AM
  5. TCC Unlock Problems
    By Rontune in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 7th, 2006, 09:46 AM
