Results 1 to 4 of 4
Thread: Cammed L76, What power should be expected.
    Lifetime Member Scoota's Avatar
    Mar 2005
    Default Cammed L76, What power should be expected.
    Hi guys, I was just wondering what power some of you are getting out of a cammed L76, I did one the other day that needed very little tuning (Customer was also in a rush to go somewhere), Idle quality was good as it was only a mild stick, I don't have the spec's on me as they are at work. The power ended up at 376rwhp. Is that about average or is there more in these engines. Any thoughts.
    Cheers Scotty.
    It's a lot easier to ask for forgiveness than it is to ask for permission.
    Member TuneMaster's Avatar
    I've tuned a few of these. I have seen different power outputs from 280 RWKW to 330 RWKW, thats 375 RWHP to 445 RWHP. Different combo's for different people.
    Lifetime Member limited cv8r's Avatar
    May 2005
    what methods are people taking to tune the L76. May have one soon,whats different to the LS1's in tuning them?
    PM me your email and I'll send you a file. On stock motors with good exhaust and intake I have run these mafless. They run slightly richer than stoich at idle but the WOT fueling can be adjusted via PE to achieve 12.8.1. Timing and KR need to also be fine tuned. The most I've seen out of a stock motor has been a ute I did with big pipes and OTR intake that made 275 RWKW. When cammed MAF Frequency is what I adjust to achieved desired AFR. This will change soon as the EFI Live guys are working on a VE Table for E38 controllers. Can't wait.
  1. Cammed Vette, can't do WOT tune....
    By The Cartel in forum Gen III V8 Specific
    Last Post: July 23rd, 2008, 02:51 PM
  2. Modified DFCO settings - not getting expected results
    By Kevin Doe in forum General (Petrol, Gas, Ethanol)
    Last Post: July 3rd, 2008, 12:58 AM
  3. Need help with cammed LS2 (getting codes)
    By black346 in forum Gen IV V8 Specific
    Last Post: October 31st, 2007, 11:44 AM
  4. Adding Headers and expected Fuel trims
    By Beer99C5 in forum Gen III V8 Specific
    Last Post: April 25th, 2007, 01:35 PM
