B6001 "Spark Dwell Time" has 2 links: GMRPM AND SAEVOLTS. I don't see an SAE VOLTS pid. I'd like to moniter coil pack voltage. Any ideas?
Joe
Joe
2003 red vert
Mods:
LPE 100mm MAF
RPM Level 6/4L60e trans
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
That might need to be gm.volts instead of sae.volts. If it needs to be changed, you can do that in the Program Files install folder of EFILive in the cal_link.txt file (IIRC). DO NOT ALTER UNTIL IT'S CONFIRMED THOUGH.
Joe
Just be aware that GM.VOLTS and SAE.VOLTS (whichever one exists) is battery voltage, and not coil pack voltage.
Joe
I don't want battery volts. You're probably right that they both are battery volts, but I thought I'd ask. I noticed that the Spark Dwell Time for the LS7 B5120(LS7file) is much lower than for the LS1 B6001(LS1)file . I'm using the LS7 table since I don't want to burn up the LS7 coil packs. But, am I getting enough spark doing that? I don't see any tables in the LS7 file that would boost volts from B5120(LS7file), so I assumed the LS7 packs are putting out more than the LS1's. I guess I could see if I can compare output specs, if I can find them.Originally Posted by joecar
Joe
2003 red vert
Mods:
LPE 100mm MAF
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
We might be getting someplace.
http://forums.corvetteforum.com/show...post1560925046
2003 red vert
Mods:
LPE 100mm MAF
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
Interesting... I would love to have a 4 channel oscilloscope just for that purpose
That would be nice, at least on this question, for me.Originally Posted by joecar
It's beginning to sound like the LS7 numbers are the ones to use. I have been and don't notice any ill affects either by logged numbers or observed. I'll try raising them when I dyno, but I don't expect any improvement since I should have had some missing. I wonder if the plugs would show anything?
2003 red vert
Mods:
LPE 100mm MAF
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
If the plugs are firing with a weak spark, they will get fouled up over a period of time.
Can you monitor the temperature of the coil packs (...using a laser pointer thermometer...) after a WOT blast...?
joecar,Originally Posted by SSpdDmon
Both have to be changed. It's GM.VOLTS and SAE.RPM.
The link text needs to change as well as the calculated link.
It's usefull to be able to compare dwell times.
Joe
2003 red vert
Mods:
LPE 100mm MAF
3.42 gears
Yank SS3600
1-7/8" AR headers
Z06 exhaust
470rwhp 437rwtq
Ok, I'll let Paul know that the links for B6001 need to be changed as follows:
SAE.VOLTS -> GM.VOLTS
GM.RPM -> SAE.RPM
