Results 1 to 4 of 4
Thread: ASPARK question
    Lifetime Member mistermike's Avatar
    Dec 2003
    Default ASPARK question
    I just completed switching over to a SD tune using the custom OS. Before logging, I forced the octane scaler to 100% to ensure that I was running the high octane spark table, defeated DFCO and PE for the log. Naturally, while logging, my ASPARK PID was at 100%.
    The tune went well. I've actually got a much tighter LTFT map than I had using MAF, performance is improved, and KR is reduced. I even was able to push the high RPM timing a bit with no negative consequences. Idle needs a bit of work, but it's not too bad.
    However, after disabling the forced scaler and returning PE and DFCO to normal, when logging I'm showing ASPARK at 0%. Wouldn't this be indicating that it's dropped to the low octane table in spite of the custom OS, or am I just missing something?
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Default Re: ASPARK question
    Quote Originally Posted by mistermike
    yes you are on the low octane spark map if the aspark is 0% , check to see how you disabled the octane scaler , did you disable it or set it to zero ?
    Make sure A0002 is not set to 0, make sure that is set to 100.
    Dec 2003
    Quote Originally Posted by GMPX
    That must be it. For logging, I set A0000 to enable and A0001 to 100. For running, I simply set A0000 to disable. I didn't think about A0002 being in play without A0000 enabled, but now the logic of it is perfectly clear.
    I must say, I am entirely impressed with the thoughtfulness and performance of the tuner. Laying a calibration down in less than a minute is a joy. I'm eagerly anticipating getting a pair of LC-1's to take advantage of the auto tune capability. Now, if I can only find a stretch of level road where I can hit 6500 RPM in 4th gear...
  1. Desired Airflow Question, not your normal question
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2010, 11:10 AM
  2. Locked out timing question for boost setup question??
    Last Post: September 13th, 2005, 03:22 PM
  3. ASPARK Relearn
    By mistermike in forum General
    Last Post: July 7th, 2005, 12:36 PM
