Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Can't get 7.4.2 with new E38 download to read cal file #12597121...help.
  1. #11
    Lifetime Member jfpilla's Avatar
    Quote Originally Posted by onfire
    I've tuned two turbo systems on the ls1 platform. This new E38 platform is wayyyy over my head....ve calcs instead of tables, etc....incredible tuning power there.
    The LS7 is just an engine. If you're using the LS1 computor you can use LS7 files as they are or convert them using the nice conversion table in EFI or just extrapolate, fill in and be creative.
    I'd rather tune the LS7 with the LS1 PCM.
    2003 red vert
    Mods:
    LPE 100mm MAF
    RPM Level 6/4L60e trans
    3.42 gears
    Yank SS3600
    1-7/8" AR headers
    Z06 exhaust
    470rwhp 437rwtq
  2. #12
    Quote Originally Posted by jfpilla
    I'd rather GM used the ECM from the 1986 TPI motors, would make my life easier
  3. #13
    Quote Originally Posted by GMPX
    I just tuned in a set of 86lb low imp injectors with EFI on a ls1 computer. Wouldn't know where to start on the LS7 PCM.
    Some of the LS7 files are helpful though.
  1. Anyway to read a HPT file?
    By turboolds in forum FlashScan V2
    Last Post: December 16th, 2008, 08:17 PM
  2. logged file can't read
    By knagel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 22nd, 2008, 01:27 PM
  3. Looking for a 12597121 cal file to add to e38
    By onfire in forum Gen IV V8 Specific
    Last Post: August 1st, 2007, 10:46 AM
  4. Need help. Trying to read ls1edit file with efilive
    By BrianC98Z28 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2007, 02:23 AM
  5. Read a 1997 Corvette File Does this look right?
    By vetteboy2k in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2005, 04:27 PM
