Results 1 to 7 of 7
Thread: What AFR in Boost?
    Apr 2007
    Default What AFR in Boost?
    I just started logging boost, it looks like I am running in the low 10's AFR in boost is that normal? The car does kind of sputter a bit in boost. I JUST went SD using CO3 and I am starting to play with the boost VE table. Thanks
    Sep 2005
    I like to shoot for around 11.5 in my truck. These motors don't like it to well if you get to lean in boost. Much over 12 and your risking denotation and broken pistons.
    Apr 2007
    I have been leaning it out 2% at a time, still in low 10's I think bottom of gauge reading will shoot for low 11's Thanks
    Member VYSSLS1's Avatar
    Dec 2005
    what boost levels are u running, should be aiming for 11.6-11.9 AFR on boost
    just dont run to much timing........
    and u will want to change it more than 2% at a time, u will be there for a year.
    Also are u running power enrichment as well, or just straight of the VE Boost table.
    Apr 2007
    I am running 10.2 - 10.5 . YES I am starting to notices takes ALOT of time @ 2 percent....LOL. I was just nervous about leaning it out and was not sure how much to jump at one time. I have not worked with the PE table yet, do you have any tips what to do in that area? I am running around 10* of timing in boost Main spark table is 13* with 3* retard on the boost table.
    Sep 2005
    Are you using the scanner and logging the BEN factor? That will tell you how rich each cell is compared to what the commanded AFR is. Sound to me like you need to get used to the scanner and use the maps a little more
    Autotune works well on COS's and boosted motors if you start rich and lean them out.
    Apr 2007
    Quote Originally Posted by kbracing96
    I am logging BEN(2bar), AFR(2bar), and Knock retard what else would you feel that I need to set A/F and timing since I am after all still getting used to this?
  1. Use MAF for off boost/2 Bar SD when in boost
    By Earl H in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 24th, 2007, 12:58 PM
  2. Boost and EGT's
    By minytrker in forum Duramax LB7
    Last Post: February 14th, 2007, 03:41 AM
  3. Can you log boost?
    By AustinL911A in forum General
    Last Post: January 5th, 2006, 07:55 AM
  4. What happens when you go into boost?
    By hpcubed in forum General (Petrol, Gas, Ethanol)
    Last Post: March 29th, 2005, 05:49 PM
