Results 1 to 10 of 12
Thread: semi closed loop
    Dec 2005
    Default semi closed loop
    i have done custom operating systems before but this ones killing i have tryed 3 differant operating systems cant get it to work.this is a 94 camaro with ls2 conversion using 99-2002 style computer.not sure what i am doing wrong to keep it out of closed loop heres 3 differant ones if i up load them right kidds waiting on dad to go eat lol
    You need to have anything but 14.63 in the B3647 table. When it see's 14.63 it will assume you want STFT. Try 14.60, that should keep it out of closed loop.
    Also, make sure you go and manually enter 100 into the parameters A0001 & A0002, when they are out of range like that you can end up with unpredictable timing figures. Actually if you put 99.9% EFILive will round it up to 100 for you and ensure it is limited to 100.
    Dec 2005
    ops i worded it back wards i cant get it to go into semi closed loop. like with custom opeating system 5 i posted.i tryed evey thing to get short turm fuel trims to work.i must be over looking some thing. i seen the A0001 & A0002 set to 100 and that being what the what it said to set it in step 6 tutorial didnt give it a though not thinking that 100 was the highest number and it was set higher. guess thats why said out of range lol guess now i know when it says out of range to lower the number even when it has the max number it still higher just cant see it. do you think thats why it wont go in to semi closed loop i tryed evey thing.i worked on it for 2 days and probly 35 reflashed just couldnt get the short turm fuel trims to work.i finaly give up and the customer picked his car up.has a big cam anyways and one o2 was dead so untill that was fixed had to stay into open loop. thanks sorry wasnt thinking when i wrote the other post after 2 days of trying to get the short trims working my head was on backwards lol
    I'll look at it when I get home tonite...
    Need to get the out of range parameters in range.
    VE table needs some work.
    Otherwise I can't see why it won't go into semi-closed loop.
    Post some logs showing actual AFR.
    Dec 2005
    Default log
    heres a log band 2 o2 looks dead.this has a big cam also ran fine in open loop so i let the guy have it that way after 35 flashes and 20 test drives i give up.also the motor was hurt first time he droped the car off it was smoking like crazy. then little later it locked up when he took it home. i will retune it after its fixed going to do a 402 for it.now looks like. yeah i misunstod the out of range undercontrol now will fix it thanks rich
    Dec 2005
    ok guess i need to give up on the semi closed lope some times it work some times it doesnt.worked last weekend on a tune.doing a differant car this weekend cant get it to work. anyone want to look at folder full of tunes and some logs i give up.guess not or the other tunes i posted on the last one would have gotten ansered never figured it out eather
    I can't figure it out either in your case.
    BTW: Your HO2S21 is flatlined.
    Oct 2004
    Which tune is the one to look at (of the three)? I've just had an email from a guy about the same thing.
    Andrew
    EFILive Crew
    Oct 2004
    LOL the email is actually from 69camaro5speed .
    I just sent you an email BTW.
    Andrew
    EFILive Crew
  1. clarification on semi closed loop SD
    By Cablebandit in forum Custom Operating Systems
    Last Post: October 5th, 2009, 01:51 PM
  2. cos3 semi closed loop
    By kostelacd69 in forum Custom Operating Systems
    Last Post: September 11th, 2009, 08:49 AM
  3. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 03:37 AM
  4. closed loop and open loop switching
    Last Post: July 10th, 2006, 08:56 PM
  5. Open Loop SD VS Closed Loop SD Advantages???
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2005, 12:25 PM
